something simple!
something simple!
Home Forums Manual machine tools something simple!
  • #218701
    here again
      @hereagain
      Having bought a 5c spin index I am making a faceplate for it with a 3/4 ” shaft”to fit the collet..Work can be attached to the faceplate for accurate marking out..
      Except I have not yet discovered how the work /collet turns! No amount of you tube has revealed this yet .
      here again
        @hereagain
        spin index help please
        #218707
        Martin Connelly
          @martinconnelly55370
          If what you have is like mine then there is a clamp screw on top that needs to be released and a pin in the disk at the collet end that needs pulling out. There is a retaining ring at the other end that may need adjustment to stop it binding on the body of the indexer. There are videos on improving the squareness of the Base that may help if you find them.
          Martin
          BasementShopGuy did the videos I am thinking of.
          Edited By Martin Connelly on 31/12/2015 14:31:12
          #218708
            Is this any help ?
            here again
              @hereagain
              Got it thank you..It was so stiff it wiuld barely turn..I think I ll oil thoroughly..
              Jonathon
