Soldering Hot rolled mild steel
Home › Forums › Beginners questions › Soldering Hot rolled mild steel
  • #7139
    nigel jones 5
      @nigeljones5
      #151091
      nigel jones 5
        @nigeljones5
        I need to SS 4 pieces of hot rolled 6mm sheet together. Since the steel has an oxidisation coating on it I guess its not a good idea to solder straight to it. Removing it seems near impossible – any ideas?
        #151098
        Ian S C
          @iansc
          fizzy,unless you want to take it off with emery cloth, or file it, you can use either the electrolytic rust removal system, or soak it for a day or so in citric acid, or similar. Although I find that brazing with Oxy A, or propane, with a neutral flame you don't need much of a clean up at all. Ian S C
          #151105
          colin hawes
            @colinhawes85982
            I usually clean up the surface with an angle grinder. Colin
            #151107
            Gordon W
              @gordonw
              Angle grinder with wire brush- must wear goggles. Acid flux, Bakers , solder will stick to all the cleaned bits no problem.
              #151179
              Ian S C
                @iansc
                Not Bakers, acid, fizzy want to silver solder, so an appropriate flux, or as I usually do borax. Ian S C
                #151182
                Gordon W
                  @gordonw
                  Sorry, I read SS as soft solder. For some reason I assumed he was soldering the sheets together prior to machining.
                  #151187
                  Ian S C
                    @iansc
                    Gordon, you could be right, fizzy can take the one that suits. Brazing little bits of steel, I use scrap sheet brass cut into strips about 5 mm wide, and borax for flux, works ok for me. Ian S C
                    #151199
                    HomeUse
                      @homeuse
                      Try dilute Hydrochldoric acid (Brick cleaner) to clean steel sheet – wash off with clean water and coat joint area with Borax paste – clamp in position and heat to just under cherry red and apply Silver Solder to edges of joints – solder will flow towards flame/heat position (Capillary action) – let cool normally – DO NOT COOL IN WATER – causes brittal joint
