Solder masking
Solder masking
Home Forums General Questions Solder masking
  • #343301
    steamdave
      @steamdave
      It is well known that solvent based Tippex (is it still available?) or ordinary pencil lead provide a good mask to prevent silver solder from going where it is not wanted. There may well be other masking agents that I'm not aware of.
      Is there any similar mask that can be applied to a job using ordinary tin/lead or electrical solder?
      The Emerald Isle
      #25840
      steamdave
        @steamdave
        #343307
        Martin Whittle
          @martinwhittle67411
          If you search for 'peelable solder mask' on Ebay / Farnell / Amazon / RS etc, you will get find products that are painted on as a liquid, but dry to a latex – like material. This is resistant to soft soldering temperatures, and then can be peeled off.
          On ebay if you search for 'solder mask' you will get lots of responses for cheaper syringes of UV-curable material; I take it that these are permanent solder masks and cannot easily be removed.
          Martin
          #343309
          Dougie Swan
            @dougieswan43463
            Tippex works for both soft and silver solder Dave
            Its all I ever use and is still available
            Dougie
            #343334
            Martin Whittle
              @martinwhittle67411
              On a related matter (but maybe wrong forumdevil), I am currently trying some 'artist's blue mask' from Hobbycraft, which is another latex mask: I don't know whether this would be suitable as a solder mask. It is intended as a temporary mask in watercolour painting.
              But my application involves using it as a mask over what I believe to be a bone inlay on an 1900 (approx) musical box, for the purpose of French polishing the wood background. It will be interesting to see what happens when I unpick the mask, with its thin layer of shellac over it .
              Martin
              #343348
              steamdave
                @steamdave
                Thanks for the replies to my question.
                It's good to know that solvent based Tippex is still available, but 'peelable solder mask' sounds an interesting suggestion.
                The Emerald Isle
                #343359
                Hopper
                  @hopper
                  Milk of Magnesia — if you can still find it.
                  #343380
                  john fletcher 1
                    @johnfletcher1
                    In the past plumbers when wiping lead pipes and underground cable jointers used a black substance known in the trade as plumbers black. As far as I remember in came in yellow tins about 1.5" or 2" high some thing like shoe polish tin but taller.The jointers mate applied a drop water swished it around onto the black substance with a paint brush and the jointer painted it on. This prevented migration of the lead based solder and when cleaned up the job looked neat. I've been looking for a supplier for some time, it seemed to have disappeared along with lead water pipe little wonder with the reputation of lead water pipe. I've got the idea that it might be based on soot or foundry waste and mixed with ????. As mentioned above I use Tippex and pencil, both work OK. John
