Yeah i have a WM16 and its just over 100kg, so it's bigger than it may seem in the picture, the table is over a metre long. And if all your considering is machining aluminium a much smaller machine would do the trick. I'd defy anyone to move one of those by themselves, even if you perform the local strongman act, it's the "top heavy" aspect of it that makes it so hard.
You buy the magazine right? Well have a look at the work produced by Mike Cox, He's made quite a few contraptions out of (mild) steel using the X1 mill and a similarly sized lathe. I can't see any reason why you should avoid morse taper tooling either.
If you want to drill large holes into focal lens blanks or whatever-camera-doo-hicky then saving the money you would spend on wm16 you could get a dedicated drill press as well as a SIEG mill, i personally didn't get on with using the mill as a drilling machine, not so much the ability but the chopping and changing between setups.
I think you might find a recurring theme with machine tools that it isn't so much what you have but good practice that counts.
Just look at some of the machines made before 1850, at that point in history much of the work we do on a mill was done all by hand.
Michael W
Edited By Michael Walters on 03/07/2016 05:04:39
