Slitting Saws
Slitting Saws
Home › Forums › Beginners questions › Slitting Saws
Viewing 15 posts - 1 through 15 (of 15 total)
  • #336635
    David Hill 5
      @davidhill5
      Hi, I am having problems with using a slitting saw to cut some cast iron eccentric straps. The teeth on the saw simply blunt after a cut of about 2mm. The straps are 10mm wide so it is not doing much cutting before becoming blunt! Has anyone any ideas of what is going wrong? The saws I am using are 0.040" thick. Thanks.
      #9049
      David Hill 5
        @davidhill5
        #336637
        roy entwistle
          @royentwistle24699
          David What speed are you cutting at ?
          Roy
          #336639
          David Hill 5
            @davidhill5
            About 700rpm. The slitting saw is 2.75" dia.
            #336640
            Brian Wood
              @brianwood45127
              Hello David,
              I can offer a couple of explanations.
              1. The castings are hard, or you are cutting through the hard outer skin
              2. The saw speed is too high or you are not feeding the saw and letting it rub
              Suggestions
              I would really do that sort of cutting with a hacksaw and then mill the cut surfaces afterwards, if the castings are hard hacksaw blades are a lot cheaper. Hard castings can sometimes have their grain structure refined by heating to red heat, soaking at that temperature for a few minutes and then cooled slowly in really dry ashes. If you have an open fire then put them in at bedtime, get them hot, pull them out of the fire and leave to cool down with the dying fire at the side of the grate overnight.
              DON'T quench them, that was what caused the hard spots in the first place
              If they are sand castings, then remove the hard sandy skin with an old file, or better still an angle grinder to get down to the metal below
              Regards Brian
              Edited By Brian Wood on 14/01/2018 10:29:42
              #336643
              not done it yet
                @notdoneityet
                Roy’s reply was was well founded. I might suggest that around 500 surface feet per minute (150m/min) is about 5 times too much. And the lower value would likely be requiring cooling. The feed rate per tooth needs taking into account, too.
                Edited to add that Brian would have been more direct re the speed , had he not been typing at the time of your reply.
                Edited By not done it yet on 14/01/2018 10:42:16
                #336644
                Chris Evans 6
                  @chrisevans6
                  It does sound like a combination of chilled (hard) casting and to quick a spindle speed. I would try nearer 400 RPM
                  #336654
                  Hopper
                    @hopper
                    Waaay too fast. Let's get back to basics. You calculate the rpm the same way as you would if you were turning a job of 2.75" diameter with a HSS tool.
                    The easy formula is 4 X cutting speed (in Feet/min) divided by the diameter (in inches).
                    Cutting speed for cast iron is about 70 feet per minute.
                    So 4 x70 = 280
                    Now divided by the diameter in inches
                    280/2.75 = 101.8 rpm.
                    So try cutting at 100rpm and see how you go.
                    (If the outer skin is very hard,  you might even give 50rpm a go.)
                    Edited By Hopper on 14/01/2018 12:00:28
                    #336656
                    Journeyman
                      @journeyman
                      I would be inclined to use a much lower speed. A mid-range cutting speed for cast iron is 70 feet/min. A quick and simple approximation can be made using the formula: RPM=4xFPM/Dia for the given 2.75" saw this would work out as: 4×70/2.75 = 101RPM (The formula gets rid of Pi and inch to feet conversions). As my maths is usually fairly ropey I stand to be correctedfrown
                      Hopper posted whilst I was typing, we seem to agree on the speed yes
                      Edited By Journeyman on 14/01/2018 12:02:29
                      #336657
                      HOWARDT
                        @howardt
                        I have sliced up a piece of 1"x 2" cast bar with a slitting saw, approximately 100 inches of cut with a 4' slitting saw at around 100rpm. The biggest problem i found was the cutter jamming so requiring frequent backing out. But had no cutter life problem and is was all hand feed on a Sieg SX2P.
                        #336663
                        Paul Lousick
                          @paullousick59116
                          I recently cut a set of eccentric castings in half, They are for a 2.5" dia eccentric and 5/8" wide.
                          Firstly, I machined the sides and bore of the castings to remove the hard outer layer, leaving material for final machining to size. Then used a slitting saw at slow speed to slice them in 2 (can't remember speed). The saw had no problem cutting thru the casting by starting the cut on a machined surface first.
                          Paul.
                          #336669
                          David Hill 5
                            @davidhill5
                            Well, thanks everyone. That was great to have so many responses. I did resort to using the hacksaw and milled the hacksawed surfaces flat. I take everyone's point about cutting speeds and will try my next job at about 100 rpm. I must pay more attention to cutting speeds! Thanks chaps, really appreciate your replies.
                            David
                            #336670
                              What hopper says.
                              In broad terms anything above 100rpm will ruin a slitting saw in short order.
                              David Hill 5
                                @davidhill5
                                I can confirm that!
                                David sad
                                #336689
                                not done it yet
                                  @notdoneityet
                                  Feed rate is also important. Cut per tooth needs to exceed a value at which ‘rubbing’ can occur.
