Hi guys,
I'm about to start work on my very first project, a Hero Engine, basically a small capped cylinder that you put water in, heat and it spins around (if you get it right).
The main component is a simple sealed tube… a short length of copper tube that is has flat ends silver soldered on… I'm thinking through the operations required and it appears to be sensible to solder one end on, chuck it and clean the join up in the lathe, before doing the 2nd end, then finally the other fittings.
This approach means that I'd be heating the compoents several times and the whole thing is small enough that I'm sure the existing silver soldered joints would be heated up a lot each time.
I think I remember reading that this is Ok as Silver solder, through some arcane process, actually needs a higher tempretaure to melt the 2nd and subsequent times… unlike soft solder which pretty much always melts at the same temp.
Am I correct here and would this approach work? Or should I try to get all the various bits arranged and heat it once for all joints?
cheers. Jerry
