Posted by Arthur Goodwin on 10/05/2021 19:03:51:
Thanks for all the advice. did,nt realise it had to be bright red.
You don't, I made that mistake and messed up several attempts because of it.
For stainless steel I use a high temperature flux such as HT5 but for copper alloys and mild steel I use an Easy-Flo flux. The flux should go clear and runny when the correct temperature is reached.
I've learnt several lessons the hard way. First you need plenty of heat (not the same thing as temperature) to get the job up to temperature quickly. The flux going clear and running tells you the temperature is correct. I've also found that holding the rod in the edge of the flame to heat it up, but not melt it, before applying to the job makes all the difference. On the last job i did, the bodies and flanges at the back, in this photo:
the silver solder flowed properly but you couldn't see any redness in the heated parts, although that was in dull sunlight rather than shade.
