Silver soldering
Silver soldering
Home Forums General Questions Silver soldering
  • #370900
    Robonthemoor
      @robonthemoor
      for fixing carbide tips onto tooling, do I need 35% or 55% silver content for best results?
      #26174
      Robonthemoor
        @robonthemoor
        Best choice for carbide tip fixing
        #370959
        Thor 🇳🇴
          @thor
          I have always used the 55% silver content type for soldering (brazing) carbide onto a steel shaft, and never had any come loose.
          Thor
          Edited By Thor on 08/09/2018 17:20:19
          #370961
          Robonthemoor
            @robonthemoor
            Ok thanks for the comment, I will buy some.
            #370965
            mechman48
              @mechman48
              I have used Sif bronze rods with Sif bronze flux over the years, tips have always been rock solid.
              George.
              #371058
              Keith Hale
                @keithhale68713
                The biggest problem to be overcome when brazing carbide is the effect of the very different coefficients of expansion of the two materials that could cause cracking.
                Help yourself by using the lowest brazing temperature ie something like 455.
                Create a thicker joint than you would normally. Say aim for 0.2mm.
                Don't quench the joint. Let it cool as slowly as you can. Immerse it in dry sand or wrap it in some insulation material like a clay wool blanket.
                Keith
