Just in case anybody finds this in a search sometime, the two are not the same as the Sieg has a larger spindle nose, but I was able to fit a Sieg SC6 backplate to a Chester DB10 Super by making a cast iron sleeve to fit inside the backplate.
Lathe Sieg SC6 Chester DB10 Super (2019)
Spindle nose 52mm 50mm
Plug bolt PCD 75mm 75mm
Plug bolt hole dia. 20mm 20mm
