Sharpening Fixture
Sharpening Fixture
Home Forums General Questions Sharpening Fixture
Viewing 25 posts - 1 through 25 (of 25 total)
  • #22793
    Alan .204
      @alan-204
      Alan .204
        @alan-204
        This is there code number for the item (EKIFX-35004B) its sold by MSC I don't' know how to get the link on the screen for it, I wanted to know if any one has one of these or knows anything about it, been thinking of ordering one but I know nothing about it and some advice would be good.
        Regards Alan.
        #128004
          Try this
          #128006
          Russell Eberhardt
            @russelleberhardt48058
            You can buy a lot of milling cutters for the price of that!
            Alternatively have a look at Harold Hall's book, "Tool and Cutter Sharpening". There he describes how to make one almost identical to the one at MSC. I made one and it works very well.
            Russell.
            #128007
            Rik Shaw
              @rikshaw
              With the correct added tool holding equipment, the right wheel setup and a fair bit of posh fettling this might give you the basic facility of grinding the side cutting edges and clearance angles on end mills and slot drills. You would need additional tooling to give you the required tilted angle to gash in and sharpen the ends.
              I think I would save my pennies and buy a second hand cutter grinder that will do both.
              For what it's worth (not much) the best cutter grinder I ever used for small milling cutters was a small floor mounted Pratt & Whitney with its rubber collets – I know that won't help you a lot but I thought I'd chuck it in anyway.
              A lot on here advocate using carbide cutters and simply replacing when blunt. Good advice which would be even better if you can find a supplier of cheap cutters.
              Good luck!
              Rik
              #128008
                As Russell says by the time you add in a decent wheel or two, means to angle the holder, etc you can buy a lot of cutters.
                I tend to just buy new, either the FC-3 ones in smaller sizes when they are on special or for larger sizes the imported ones from the likes of Richon will do for most jobs at about £1.50 for a 1/2" cutter it does not work out too pricy.
                Edited By JasonB on 27/08/2013 17:33:15
                #128010
                Clive Hartland
                  @clivehartland94829
                  I have no connection with Cromwell but their sale brochures always have bargains with milling cutters.
                  The latest, No. 83. for Aug. is an eyeopener with some cutter prices you could not refuse.
                  #128048
                  Alan .204
                    @alan-204
                    Thanks chaps that's answered the question, do we know of any one who provides a sharpening service so I could post them, Jason thanks for posting the link you will have to tell me how you do that someday.
                    Regards Alan.
                    #128049
                      Cost wise anything much smaller than 10mm or 3/8" is not worth getting done professionally and only good quality cutters over that.
                      There is a guy who offers tip only sharpening on Homeworkshop site, think its about £1.00 a cutter
                      #128058
                      JohnF
                        @johnf59703
                        Alan,
                        Only saw this late tonight, I bought one of these and sent it back, would be OK if you want to use it as set of castings and rework the tool. The main spindle is carried on screws with a single ball bearing set in the end which does not revolve and consequently they wear VERY quickly. The basic concept is good but the quality leaves a great deal to be desired.
                        Just my opinion and others may think otherwise.
                        #128063
                        JDEng
                          @jdeng
                          Alan,
                          Have sent you a PM.
                          John.
                          #136268
                          Robonthemoor
                            @robonthemoor
                            I just bought one, sound like I have bought a lemon. Will try it see how we get on.
                            rob
                            #136275
                            John Rudd
                              @johnrudd16576
                              Either I'm not registering something…….but this unit seems difficult to use….
                              Can anyone shed any light on the intended use?
                              i'm just not understanding the instructions supplied, help appreciated.
                              #136574
                              Arnie Burrell
                                @arnieburrell
                                Hi Alan,
                                My first post so hello to all I've been observing for quite a while some very interesting stuff on here for a newby.
                                I have already communicated with Andrew Johnston via another forum I'm also building a 4 inch Burrell.
                                Alan if you were still interesterd in the fixture there is a new one on fleabay, under tool cutter grinder, and a video of a similar device being used on http://www.bedroom-workshop.com Hope this has been some help.
                                Arnold
                                #136597
                                John Rudd
                                  @johnrudd16576
                                  Arnold,
                                  I tried to look for the video on the b/room workshop page but can't locate it…
                                  do you have a link please?
                                  #136598
                                  Arnie Burrell
                                    @arnieburrell
                                    John You're right I can't find it myself now but I believe it worked in a similar fashion to this
                                    Arnold.
                                    #136651
                                    Anonymous
                                      Hi Arnold,
                                      Welcome to the forum! How are you getting on with your engine?
                                      #136690
                                      Arnie Burrell
                                        @arnieburrell
                                        Hi Andrew.
                                        Making good progress with the Burrell. All gears faced bored ready for gear cutting. Front hubs and axle machined. Working on the front end ,smoke box, perch bracket , fork nearly done bit of milling required, Have also turned the smoke box door and name rings. need to do the hinge next. As you can see I've been doing the straight forward stuff first. I look forward to your threads on model engineering and glean a lot of info, and thanks to the rest of you forum contributers for the support and insight you give.
                                        I expect I'll be in touch soon, keep the setups coming.
                                        Regards Arnold.
                                        #137681
                                        Robonthemoor
                                          @robonthemoor
                                          Hi John Rudd did you ever get any info on the end mill sharpener? I have one & find it difficult to use, half a day setting it up, can only get the shaft to 3 degree, that's with the small shaft in not used the large one as yet! instructions are US.
                                          Rob
                                          #137683
                                          John Rudd
                                            @johnrudd16576
                                            Rob,
                                            I sold it on fleabay…..
                                            i'll not be as hasty to spend my cash in future….
                                            #137685
                                            Danny M2Z
                                              @dannym2z
                                              Posted by Russell Eberhardt on 27/08/2013 17:16:30:
                                              G'day, best thing I ever made was Harold's adjustable table from the book. If I can do it anybody can. Make one!
                                              * Danny M2Z *
                                              #137686
                                              Robonthemoor
                                                @robonthemoor
                                                Ho" did you get a good price? I will carry on.
                                                #137692
                                                John Rudd
                                                  @johnrudd16576
                                                  Nope,lost money on it….
                                                   I'll crack on with HH's tool grinding table I started……
                                                  Edited By John Rudd on 12/12/2013 19:30:14
                                                  #137695
                                                  Robonthemoor
                                                    @robonthemoor
                                                    Al204 has made one, works well he loves it. Then he talked me into buying one of these"" he likes a leg pull.
                                                    Rob
                                                    #137696
                                                    Alan .204
                                                      @alan-204
