Shaper 3 phase or Single
Home › Forums › General Questions › Shaper 3 phase or Single
Viewing 25 posts - 1 through 25 (of 30 total)
  • #137731
    lee hawkins 1
      @leehawkins1
      Hello,
      I am now the owner of a really nice condition Elliott 10m Shaper, it's fitted with a dual voltage 3 phase motor, my electrics is single phase, I don't know really what to do, do I fit a single phase motor on it or do I buy a inverter? the inverter from drives direct is going to cost me £135, expense I don't really want, I already do have a single phase motor do nothing, are any other solutions out there?
      lee
      #23004
      lee hawkins 1
        @leehawkins1
        #137734
        Russell Eberhardt
          @russelleberhardt48058
          There shouldn't be any problem using a single phase motor of similar power rating. Depending on your three phase motor design it may or may not be possible to use it with the inverter without modifications.
          Russell;
          #137736
          Ian P
            @ianp
            Lee
            I would go the inverter route every time and not even think about swapping motors. If the 'inverter' is a VFD (which it should be for over £100) you will not regret it. OK its a lump to fork out but you will forget the cost once you use it.
            I have no shaper experience since school metalwork but I would think its one machine that would really benefit from variable speed. There are numerous other advantages with a VFD like really slow speed (with very little torque) which is ideal for checking the setup. With a normal contactor its all or nothing whereas a VFD can be set to have gentle acceleration etc.
            I have VFD on most of my motors (including the usual lathe, Mill, linisher, pillar drill etc), most have come from eBay and none cost me more than £35.
            Ian P
            #137737
            Saxalby
              @saxalby
              I have no problems running my Boxford 8 in. shaper on a single phase motor.
              Barry
              #137740
              James B
                @jamesb
                Hi Lee,
                One thing to be aware of is motor speed. I have an Elliot 10M, and the 3 Phase motor is 6 Pole, meaning it runs at around 900 RPM. Usually 1 phase motors are 4 Pole – 1425 rpm approx. If you go for a straight motor swap with one of these, your ram speeds will increase accordingly, if you do not adjust the pulley sizes.
                I ended up leaving my original motor and running mine from a rotary converter – a bit noisier, but all runs fine.
                Good Luck,
                James
                #137741
                _Paul_
                  @_paul_
                  From an earlier post here
                  You could run it on an RPC which should be cheaper to make than the cost of an Inverter, that said the inverter will give variable speed and a lovely smooth finish.
                  As a comparison my Alba 1a has a 1/2hp 3Phase motor and can produce a reallysmooth finish.
                  My Elliott 10m has a 3/4hp single phase and will not produce the same quality finish no matter how much I tweak the setup/tooling/lubricant.
                  Similar behaviour from both my single phase Boxford 8" and 7" Atlas.
                  Paul
                  #137742
                  James B
                    @jamesb
                    Hi Lee,
                    Also, if you send me your email address on a PM, I have a PDF manual for the 10M I can send you if you need one.
                    James
                    #137743
                    Robbo
                      @robbo
                      Lee,
                      Have an Elliott 10M, 3-phase as usual. Did manage to find a single phase motor of the same speed, as James has said its an unusual speed, but prefer it with the 3-phase and an inverter. Only use the inverter as a phase converter, and don't use it for variable speed etc, still use the Elliott gearbox/pulleys.
                      The price you quote seems expensive for an inverter to run a 1/2 HP motor, would have thought about £90 would get a good one,  1/2 to 3/4 HP.
                      Phil
                      Edited By Robbo on 13/12/2013 13:51:57
                      #137753
                      Lambton
                        @lambton
                        Lee,
                        Keep the 3 phase motor and get an inverter. Talk to:
                        Gavin Oseman
                        Malvern
                        WR14
                        UK
                        01684 574966
                        [email protected]
                        He supplies used inverters from quality manufactures at sensible prices.
                        I have not used his services personally but I have friends who are very satisfied with his services.
                        Eric
                        #137757
                        john fletcher 1
                          @johnfletcher1
                          Before buying an inverter,consider you already have a 900 rpm motor which now doubt can be reconnected in Delta, why not make up a control box using two banks of capacitors. Both banks are used for starting and then just one for running. The details, values etc are in the late JIM COX's excellent book. EX fluorescent lamp circuit capacitors work well.Ted
                          #137790
                          lee hawkins 1
                            @leehawkins1
                            Thanks everyone for the replies
                            Given me something to think about, always worth asking about other peoples thought on things like this, recon I will be going the inverter route, I have never ran a 3 phase motor before, I know everyone says they run allot smoother/quieter, that will be nice.
                            I have been quoted a price from Drives direct, they quoted me product code and price, Can anyone on here tell me exactly which one to buy, if I searched around EBay for second hand, I am not exactly sure which one to look out for.
                            lee
                            #137792
                            Martin Walsh 1
                              @martinwalsh1
                              Posted by john fletcher 1 on 13/12/2013 16:01:25:
                              I done this on my Elliot shaper it does work but you do lose a lot of power
                              from the motor.
                              congrats on getting the 10m shaper you will find it a great useful addition to the workshop
                              best wishes martin
                              Edited By Martin Walsh 1 on 14/12/2013 09:20:49
                              Edited By Martin Walsh 1 on 14/12/2013 09:25:14
                              #137793
                              Russell Eberhardt
                                Before buying an inverter make sure that the motor can be converted from star (415 V) to delta (240 V). Inverters that produce 415 V are significantly more expensive. I have fitted inverters and new three phase motors to my lathe and my mill with new Marelli motors from Drives Direct. The motors are designed for use with inverters and have more cooling than usual so that they can run continuously at low speeds. I don't know if you will be running the shaper much at low speed but it's something else to think about.
                                Russell.
                                #137794
                                Robbo
                                  @robbo
                                  Rusell,
                                  The Hoover motors fitted to Elliotts are dual voltage. But see also the OP!!
                                  Phil
                                  #137801
                                  Ian P
                                    @ianp
                                    Posted by lee hawkins 1 on 14/12/2013 06:54:46:
                                    lee
                                    Lee
                                    There is no 'exactly which one to buy'. There are dozens at least of VFDs that could be used. One of the replies suggested Gavin Oseman and although I have only ever seen his adverts I think he is knowledgeable and his prices look good so unless you know much about the subject I would give him a call.
                                    Ian P
                                    #137804
                                    Ady1
                                      @ady1
                                      I already do have a single phase motor doing nothing, are any other solutions out there?
                                      Put the single phase on and see how it goes
                                      When I got my lathe I got a new motor and chucked the old original to one side
                                      However, when I got more serious the newer motor was running for hours and getting seriously hot because of the amount of work the lathe was doing
                                      So I put the "old clunky" motor back on and it runs for hours and hours with no serious heat issues
                                      It looks a bit like this one
                                      The old stuff is "built to run forever" and should never be discounted as an option
                                      Mine has a fan blower at one end of the spindle and the pulley at the other end and runs happily all day on a 5amp fuse, 0.5HP
                                      Edited By Ady1 on 14/12/2013 11:31:27
                                      #137817
                                      DMB
                                        @dmb
                                        Ady1,
                                        I have read somewhere that older motors were more heavily built with a certain type of insulation and could run cool for hours and modern motors lightly built get very hot and have a different type of insulation which will withstand the heat. They are supposed to be dsigned to run at a high temp.
                                        John.
                                        #137836
                                        lee hawkins 1
                                          @leehawkins1
                                          I am in contact with someone who has a Danfoss VLT2015 1.3kw Single Phase Input 3 Phase Output Inverter, they want £75 for it
                                          As the motor on my shaper is dual voltage it should run ok, but the motor needs to be change from star 415v to 240v delta, is this a simple task or do I need to go pulling wires out the motor?
                                          lee
                                          #137837
                                          _Paul_
                                            @_paul_
                                            Dual voltage (220/415v) motors should have a junction box on them which may if you're lucky have a wiring diagram in it, you will have to open the junction box cover and alter the "links" (brass strips with a hole either end) motors will vary by manufacturer but typically should look something like this
                                            Example of a STAR Mode (415V) Connection
                                            Example of a DELTA (220V) Mode Connection
                                            Paul
                                            #137838
                                            lee hawkins 1
                                              @leehawkins1
                                              Paul,
                                              Thanks for that
                                              This dont look too Brain taxing, can it be as simple as that, .
                                              lee
                                              #137839
                                              Lambton
                                                @lambton
                                                Lee,
                                                Yes it is that simple – one of the benefits of a dual voltage 3 phase motor. Another benefit is ease of reversing the direction of rotation by just interchanging any two of the incoming power wires (not necessary when using an inverter which will have a built in F/R switching facility).
                                                Some older fractional horse power 3 phase motors that do not require star /delta starting are often connected in star only (400 v). The only option with this type is to dismantle the motor, dig out the star point and rewire the motor in delta. This is best left to a motor repair specialist.
                                                Eric
                                                #137845
                                                lee hawkins 1
                                                  @leehawkins1
                                                  Thats good,
                                                  I didnt fancy stripping a perfectly good motor down,with a good chance of messing up, been and bought the inverter now, so all should be good
                                                  lee
                                                  #137846
                                                  lee hawkins 1
                                                    @leehawkins1
                                                    Just checked and had a look inside the connection box on the motor, and inside the lid is the wirring diagram for both star and delta.
                                                    lee
                                                    #137847
                                                    OuBallie
                                                      @ouballie
                                                      Lee,
                                                      I'm running my Boxfprd 8" with a VFD, and it's a pleasure to use.
                                                      The same VFD runs the motor on my drilling machine, which is even more of a pleasure now that I can get the speed spot on.
                                                      Geoff – Enjoying a mug of Kai.
