Setting an internal micrometer
Home › Forums › Workshop Tools and Tooling › Setting an internal micrometer
  • #341492
    John MC
      @johnmc39344
      I have a Fowler-Bowers internal micrometer, 0.50" to 0.62" range, the type with 3 expanding pins. While it is accurate to the various setting rings I have, the scale on the thimble does not quite line up with the scale on the sleeve, if that makes sense, enough to cause a reading error unless I am careful.
      On an external micrometer this type of error can usually be corrected by moving the sleeve axially with a tiny C spanner.
      I've looked at the manufacturers website, it explains resetting the thimble to a gauge but not resetting the sleeve.
      Its bound to catch me out one day so I would like to reset the sleeve,anyone know how?
      John MC
        @johnmc39344
        #341504
        ronan walsh
          @ronanwalsh98054
          Can you not send it back to the manufacturer for calibration ? Might be the easiest way to do it.
          #341536
          vintagengineer
            @vintagengineer
            I will have a look at mine tomorrow. Have you tried unscrewing the the thimble? I think there is an adjustable ring under the thimble.
