Set screws or threaded rod
Home › Forums › Beginners questions › Set screws or threaded rod
Viewing 15 posts - 1 through 15 (of 15 total)
  • #166324
    Eric Cox
      @ericcox50497
      When fastening a steam chest to a locomotive cylinder block would you use hex. hd. set screws or threaded rod and nuts.
      #7332
      Eric Cox
        @ericcox50497
        #166329
        roy entwistle
          @royentwistle24699
          Eric Studs and nuts
          Roy
          #166331
          Nick_G
            @nick_g
            Posted by Eric Cox on 12/10/2014 09:40:32:
            Wait until Jason sees this.! surprise
            He will consider it nothing short of blasphemy that you should even consider hex screws let alone mention them over studs and nuts. And also the correct profile of nuts.! winkwinkwink
            Nick
            #166334
              Who Me? At least you were thinking of hex head not slotted or socketwink 2
              As said the prefered method is to take some rod, thread the ends and then use nuts and washers. There is also a practical reason for doing it this way, when you come to set the valve timing you can leave the valve chest cover off to see whats going on while the chest is still supported by the studs, can't do that with screws.
              J
              #166336
              John Baguley
                @johnbaguley78655
                Actually a lot of steam chests/covers on locos are held on with csk head slotted screws. Often there is not enough clearance between the valve chest cover and the running board to get nuts in. Sometimes the steam chest is also secured to the block by a couple of csk screws through the steam chest only and between the normal fixings. That way the chest is still secured when the cover is removed for valve timing etc. A chassis I'm working on at the moment has that feature.
                As suggested though, studs and nuts are the best way really. I've had a few locos where someone has been a bit over enthusiastic tightening bolts and stripped the threads in the block sad
                julian atkins
                  @julianatkins58923
                  would eric's Northumbrian loco have had square nuts originally in fullsize? (circa 1830)
                  cheers,
                  julian
                  #166342
                    Posted by JasonB on 12/10/2014 10:12:41:
                    … the prefered method is to take some rod, thread the ends …
                    Thus making proper studs. yes
                    I know little of Steam practice [either full-size, or miniature] but it seems that normal "good engineering" principles would apply.
                    julian atkins
                      @julianatkins58923
                      (i stand to be corrected but Stephenson's Rocket of 1829 vintage as preserved has no hex nuts – they are all square nuts)
                      #166357
                      Ian S C
                        @iansc
                        Julian beat me to it, if your prototype is old enough, square head bolts, and studs with square nuts. someone else can start the argument as to which way up the nut should be.(don't go there),
                        Ian S C
                        #166361
                        JA
                          @ja
                          Posted by Ian S C on 12/10/2014 12:08:19:
                          Ian S C
                          Please go there! I am making a Bolton & Watt bell crank engine.
                          JA
                          #166371
                            Posted by JA on 12/10/2014 12:29:25:
                            Ian S C
                            JA
                            JA … For reference here is "there"
                            Enjoy
                            JA
                              @ja
                              MichaelG
                              Many thanks.
                              JA
                              #166414
                              Eric Cox
                                @ericcox50497
                                Sorry folks (I can hear the cries of despair already) I'm not going for authenticity at the moment I just want a loco that works so hex nuts it will be and probably stainless. However, one of my future projects will be am Armstrong muzzle loaded gun and that WILL have square nuts.
                                #166425
                                john kennedy 1
                                  @johnkennedy1
                                  Are we talking stainless for the studs ? or doesn't it matter?
