Hi Brian,
Thanks! I really like Fusion 360, mainly as it had (has?) a free usage for hobby purposes, and was the first free program that was worth a damn – and I tried a lot! The tutorials are good, the community support excellent, the program effective, quick and intuitive. The only area I found difficult was constructing compound curves, although one I'd got the hang of it, I wondered why that had been such a problem..
I think you may still be able to download if free on a "start-up license" and then select hobby usage.
There's quite a mix of materials now in the turrets, some sheet brass to stiffen cupola parts, an alloy base-plate (bearing surface), much SLS nylon, and some ABS printing (for dimensional accuracy). There's virtually no glue on it anywhere, ir's entirely held together with M1 and M1.6 machine-screws, as SLS nylon can be tapped.
Edited By Timothy Huff on 24/02/2019 10:59:56
Edited By Timothy Huff on 24/02/2019 11:00:24
