Various comments.
It was said that pre WW 2, Austin Motor Company left cylinder block and head castings out doors for at least two years to stress relieve.
As an Apprentice, during my 3 month stint n the Toolroom, on one Friday afternoon, I was given a machined Aluminium casting to scrape and blue. It was left flat. On Monday morning, the same could not be said of it!,
More recently, a cylinder block which had been finish honed before assembly, if measured after the engine had been tested and stripped could show up to 0.004" ovality on a 3.875"bore.
A block which had been relinered and reused always gave better results.
One day, a load of castings, which had stood outside for some months, were fed into the transfer line. Every cutter was promptly ruined, and nothing could be done until the wreckage emerged at the other end.
Investigation showed the castings to be extremely hard. From the cast date it was established when the metal had been poured. At the time the foundry was having the outside walls replaced. The very hot castings had been knocked out out of the boxes, and snow had blown onto them, chilling them!
Camshafts were locally hardened by placing chills in the mould so that the cams would be chilled and hardened while the shaft proper was left soft.
