Sealey mighty mig 150
Home Forums Help and Assistance! (Offered or Wanted) Sealey mighty mig 150
Viewing 23 posts - 1 through 23 (of 23 total)
  • #348266
    sean logie
      @seanlogie69385
      Has anyone replace the liner in one of these ? I know how just not sure of which one . The one I took out of my welder was in 2 pieces which doesn't seem right to me . From where the liner enters the gun for about 1/2" in ,from there there was a another piece of liner the length of the gun up to the nozzle . Is this right or not . I've been a stick welder up to now ,so I'm not up speed on the mig welder and it's in's and outs . I would've thought it would need to be one continuous piece .
      Sean
      sean logie
        @seanlogie69385
        Liner
        #348279
        Hacksaw
          @hacksaw
          I have one . Yes , mine is a separate piece , which is a right pain, as when loading a new wire ,invariably means taking the gun apart , as it never finds the hole in the tubing . Since it's on the bend in the nozzle it eventually wears through too..from the friction of the moving wire , and then the shroud goes live too !! Any old plastic tube kicking around that's the right bore seems to work as a replacement ok …like a bit of airbrush airline blush..( cowbow , i am  )
          Edited By Hacksaw on 31/03/2018 15:42:24
          #348280
          Hacksaw
            @hacksaw
            Those red tubes that come with WD40 ..a bit of that works too on 0 .6 wire in an emergency ..
            So i've heard…blush
            #348282
            sean logie
              @seanlogie69385
              Which flux core do you chaps suggest .
              Sean
              #348285
              Hacksaw
                @hacksaw
                Gasless wire ? Never tried it . Don't you have to reverse the gun polarity with that stuff ? I've only ever used CO2 or Hobbyweld 5 gas
                #348291
                  Posted by sean logie on 31/03/2018 16:03:19:
                  Sean
                  Depends what you are welding!
                  #348293
                  sean logie
                    @seanlogie69385
                    Mainly mild steel .
                    Sean
                    #348298
                      Bog standard flux-cored mild steel wire then
                      #350210
                      sean logie
                        @seanlogie69385
                        Now I don't know much about electronics,so I'll try and explain . The relay that powers the the wire feed kinda pleases it's self when it works lol . I noticed yesterday there was a hole in the side of the plastic cover ,I also noticed it was sparking and flashing when I pulled the trigger on the gun .Then when it didn't work it was clicking ,now I think even I know that's not how a relay should behave wink .
                        Here's the culprit
                        To replace the relay ,is it  a case of touching the connectors on the back of the PCB with the hot soldering iron  .I'm a little concerned about damaging the PCB in doing this . Any tips ?
                        Edited By sean logie on 15/04/2018 07:39:48
                        #350214
                        Gray62
                          @gray62
                          Ideally you need to remove as much solder as possible from each of the pads before trying to remove the relay from the board. Get yourself some solder wick. The wick will take up most of the solder and will also sink some of the heat so reducing the risk of damaging the pads on the board. Don't keep the iron on each pad too long, of all the solder is not removed, let the pad cool and do another one, then go back around. Too much heat in one go will risk lifting the pad and burning the pcb.
                          #350215
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi Sean, get yourself some de-soldering braid. If your hurry to a Maplin's shop, you maybe lucky to get some.
                            Regards Nick.
                            Graeme beat me to it.
                            Edited By Nicholas Farr on 15/04/2018 09:01:08
                            #350230
                            doubletop
                              @doubletop
                              As the relay is completely stuffed. Take a note of all the markings to help you search for a replacement. Then carefully break off the outer case and using snips cut away as much as the relay as you can. You are trying to get it down to 4 separate connections coming out of the board.
                              Using pliers grip the connection on the component side and unsolder on the solder side and pull the connection free. Repeat for the other three.
                              It may seem a bit drastic at first but it is far easier than trying to wrestle out 4 connections at the same time.
                              Pete
                              #350231
                              doubletop
                                @doubletop
                                It looks like it is one of these
                                Data Sheet here
                                http://www.hongfa.com/pro/pdf/HF102F_en.pdf
                                Beware when searching Ebay. You want a 24v version and they all seem to be selling the 12V version which appears to be JQX 102F. However some are advertising the HF 102F but as 12v which you don't want.
                                Pete
                                Edited By Doubletop on 15/04/2018 09:28:33
                                Edited By Doubletop on 15/04/2018 09:49:53
                                #350247
                                sean logie
                                  @seanlogie69385
                                  Posted by Doubletop on 15/04/2018 09:24:02:
                                  Pete
                                  This was my plan Pete ,thanks
                                  Sean
                                  #350248
                                  sean logie
                                    @seanlogie69385
                                    Posted by Nicholas Farr on 15/04/2018 08:37:41:
                                    Regards Nick.
                                    All ready ordered wink
                                    Sean
                                    #350249
                                    sean logie
                                      @seanlogie69385
                                      Posted by Doubletop on 15/04/2018 09:26:50:
                                      Data Sheet here
                                      Pete
                                      Thanks again Pete , I nearly fell foul on the 12v version .Mine is the HF102F 24v 20A
                                      Sean
                                      Edited By sean logie on 15/04/2018 11:47:14
                                      #350307
                                      Anthony Drake
                                        @anthonydrake63078
                                        On the subject of gas less wire I have used this type of wire with and without gas on 400 amp machines, I am using machine Marts 0.9mm wire which I have used on car body work on a 100 amp mig which is good wire compared to the industrial wire I have used.
                                        Regards Tony laugh
                                        #350334
                                          Anyone got a theory as to why Sean's relay should fail like that? My first thought was that there's a dud capacitor across the contacts but the symptoms don't match. Could it be physical damage, something whacked into the case in the past?
                                          I prefer a desoldering pump to wick; both are useful depending on the job.
                                          doubletop
                                            @doubletop
                                            Posted by SillyOldDuffer on 16/04/2018 09:37:17:
                                            Here is the parts list with the circuit diagram **LINK**
                                            The only thing the relay does is switch the power transformer, maybe the back emf of a lot of repeated heavy current welding (switch setting on MAX 1)  has finally killed the relay. Just a case of component mortality?
                                            Pete
                                            Edited By Doubletop on 16/04/2018 12:15:39
                                            #350382
                                            sean logie
                                              @seanlogie69385
                                              The link for the welder is different setup to mine unfortunately.
                                              Sean
                                              #350421
                                              doubletop
                                                @doubletop
                                                Posted by sean logie on 16/04/2018 16:23:18:
                                                Sean
                                                Sean
                                                Maybe but the overall principles of the design will be similar. Here is another link with various posts of circuit diagrams for MightyMig variants
                                                Maybe different models but in all the cases the relay switches on the primary to the transformer. The variation is the way the voltage control taps on the transformer are selected.
                                                One other thought is the state of the transformer and whether you've got a short between the coils and it is overloading the relay. Give it a visual check to see if there is any obvious arcing. There was a time I could do the maths on transformers and possibly advise a method of checking with a meter. Unfortunately those days are long gone.
                                                Otherwise I'd suggest you jump on the mig welding forum in the link I've given you and ask the same question there.
                                                Pete
                                                #350422
                                                doubletop
                                                  @doubletop
                                                  Or
                                                  Pete
