riveting
riveting
  • #502786
    Peter Etherington 2
      @peteretherington2
      Just wondering if I could use one of those cheap 1/2 ton arbor presses to set rivets in some thin plate. Peter
      #19981
      Peter Etherington 2
        @peteretherington2
        #502796
        Anonymous
          Depends on the rivet size and material?
          #502801
          Peter Etherington 2
            @peteretherington2
            1/16 brass rivets to sandwich very thin stainless and thin aluminium
            Edited By Peter Etherington 2 on 22/10/2020 19:44:10
            #502811
              Should be OK on the stainless but you may find that the aluminium tends to bulge outwards if the rivits are near an edge.
              #502888
              Peter Etherington 2
                @peteretherington2
                Thanks very much. Peter
                #502908
                DMB
                  @dmb
                  Hi Peter,
                  Not done much riveting but one occasion the formed heads had a sort of collar and the pre – formed heads likewise, if I remember, it was many years ago. I was advised by a fellow member who trained as a school metalwork teacher to buy a riveting snap set from the same source as the rivets. Then one should fit the other properly. Unfortunately my supplier at that time, ol' Chas. Kennion now long gone! So I would need to try what I still possess or get new lot.
                  Regarding your query, if in doubt, try out what you want to do on some spare bits of identical metals and of course, same thickness(es). You could have some difficulty as JasonB said above, asthe metals are dissimilar, one being soft as chewing gum and the other considerably harder.
                  HTH and good luck,
                  Peter Etherington 2
                    @peteretherington2
                    thanks john
                    #502926
                    Martin Kyte
                      @martinkyte99762
                      Chas. Kennion now long gone! ?
                      Not so much gone as evolved into GLR Kennions
                      Unless you are talking about a different Kennion
                      regards Martin
                      Edited By Martin Kyte on 23/10/2020 13:38:58
