Hello All.
Been a while since I asked for advice on this as health issues had stopped all really physical work – workshops and the like. However, now back to some form of fitness, I've finally stripped the spindle.
Firstly, the videos on the Grizzly G0704 machines helped as most of the replacement was similar although, now that I've stripped the spindle, the bearing sizes are different on the Warco to the Grizzly. The bearings are NSK HR 32005 XJ.
Also, in the videos, no mention is made of the large bearings in the head, that the internally splined, gears run in. Whilst I understand that the quill is tightly locked in its uppermost position at all times for CNC work, do these bearings play a big part in true running of the spindle or is it just the spindle bearings?
Having stripped the taper roller bearings out of the spindle and closely examined the outer races, there are some curious darker "patches" of wear(?) diametrically opposite, each of about 1/5th of the circumference of the middle of the race. I assume that this is probably the cause of the chatter? Anyone have any ideas? Where would I get advice on this?
Any help would be greatly appreciated.
Many thanks,
GeoffB
