Regulator using a 8mm gas valve help please
Home › Forums › Locomotives › Regulator using a 8mm gas valve help please
  • #173709
    Ron Hancock
      @ronhancock63652
      Hi can any one help i am building my black 5 boiler i want to use a 8mm gas valve but cannot see how they can be connected to normal regulator handle.
      Can anyone tell me how they connect please i am told they are often used but no more info.
      I know you have to change lever which is easy but how on earth do you conect from their please.
      Ron
      #1352
      Ron Hancock
        @ronhancock63652
        Black 5
        #174332
        nigel jones 5
          @nigeljones5
          ive used them to great effect. fitting is all down to the access you have but basically remove the existing arm and build a parallel linkage
          #174343
          Ron Hancock
            @ronhancock63652
            Hi i cant visulise how it can work using normal regulator lever.
            I can see some fit into smoke box but i want the normal regulator control.
            do you have a diagram as i am still building the Boiler.
            I am at the stage of ready to fit the Stays.
            Happy new year
            Ron
            #174641
            nigel jones 5
              @nigeljones5
              My only drawing isn't compatible with this site so I cant upload it. In a nutshell you need to end up with a regulator linkage with a square end, and make a boss to fit into the valve which accepts the square end. I take it that you want the regulator inside the boiler? Its a fidly job, but I locate and secure the valve via the inside of the steam dome with the steam exiting via steambox in normal position. I will try to sketch on other software.
              #174642
              Ron Hancock
                @ronhancock63652
                The boiler inspectorors at our club suggest using a screw type regulator saying much simpler and more reliable.
                What do you think i already bought the Valve
                Ron
                #174654
                nigel jones 5
                  @nigeljones5
                  use the valve!!!!!
                  #174722
                  Ron Hancock
                    @ronhancock63652
                    yes
                  Home › Forums › Locomotives › Topics
