Record Vice Q/Release Trigger Spring
Home Forums Workshop Tools and Tooling Record Vice Q/Release Trigger Spring
  • #428070
    Chris Lacey
      @chrislacey68761
      I'm looking for a Q/Release Trigger spring for a Record 52 1/2 Vice as mine has snapped.
      It's the flat coiled spring steel one.
      I would be much obliged if anyone has one for sale, knows where I can pick one up or suggest where I can get one made as a one off withouit breaking the bank?
      Thanks very much in advance.
      Chris Lacey
        @chrislacey68761
        #428076
        Meunier
          @meunier
          If you have no luck with the direct replacement, how about measuring the thickness/width of the spring and obtaining an equivalent clock spring from one of the horological suppliers and cutting off the required length ?
          DaveD
          #428083
          David George 1
            @davidgeorge1
            Have you tried Irwin the manufacturer.
            T52EDL Trigger Spring & Nut (fits all sizes) 0734442038047 – 1 14.33 17.20
            David
            #428134
            Chris Lacey
              @chrislacey68761
              Thank you for the replies gents.
              The spring is a bit of a beast so I’m wondering if a clock spring might struggle with the workload but I will look in to it.
              I’m also going to contact Irwin in the morning with tightly crossed fingers. You’ll no doubt be aware that they don’t make ‘em like they used to so I’m hoping that they still carry the old parts, as some are showing as discontinued.
              Best wishes and I’ll let you know….
              Edited By Chris Lacey on 08/09/2019 23:00:30
              #428219
              Bazyle
                @bazyle
                You could use piano wire or with a bit of engineering to provide a lever and anchor point a 'regular' spring.
