TO MARTIN H … so far no real problems … this bearing wear is the first major problem … the lathe has been used and used and … etc. for a long time … I did swop the motor for a 3 phase variable speed drive … that was the best thing I have ever done … the original motor was advertised as continous run … mine was not … after 30 or 40 minutes it got hot and noisy !! … very long story … but I eventually bought the CL 400 unit from Newton Tesla … the new motor fits neatly behind the lathe at the left side.
The carriage adjustment screws are underneath … 2 pieces of heavy timber 6 x 3 inches are useful to prop the lathe up … the tailstock clamp was a short Allen key … I have swopped this for a long Allen key with a tee handle.
The lever to clamp the carriage to the leadscrew was very tempting to move when screw cutting … I drilled a hole in the front of the casting to put a lock on it.
There was a misprint in the chart for screwcutting … given the change-wheels supplied it was not possible to cut a 16 TPI thread … no doubt this misprint has been corrected by now.
I would buy a parting-off tool about 2mm wide …. the one supplied is 3 mm … for small bits of brass it is very heavy to use and wastes lots of material … a smaller tool might also save some of the sideways wear.
This lathe has spent its life cutting brass, bronze and gunmetal … it has also been used for small pieces of mild steel and stainless steel … if it was cutting lots of steel 2 inch diameter I think it would have died a lot quicker.
Would I buy another ? … definitely … for the smaller sizes of material I use it is perfect … if I just ate beans on toast for the next year I would buy one now and leave it set as milling machine.
I did buy the faceplate and 3 chucks … 4 jaw self-centering is superb.
TO HOPPER … I like the phrase "spit-sizzlin hot" … your workshop sounds just the same as mine … I am not an expert in anything … my wife says I know nothing !!
