Posted by Antony Powell on 27/11/2017 08:38:39:
"don't use acetylene but propane as acetylene is not allowed on site"
Never heard that one it's usually just cost propane is far cheaper (unless you're outside the UK then i wouldn't know, never been told this on any site I have and do work on ever…)
I was intrigued by that too, but it does make sense depending on the Site. For example it's not allowed at Heathrow as per this Instruction.
If you're running the world's busiest airport and want to minimise the disruption caused by a fire I can see it pays to guarantee that Acetylene Cylinders aren't involved. When an Acetylene Cylinder is overheated they sometimes start an internal process of decomposition ending in an explosion up to a couple of hours later. So the procedure is to keep 200 metres away from hot Cylinders for several hours after the fire's out and everything's cooled down.
I suppose most 'ordinary' sites don't need to restrict the use of acetylene because the impact of an incident on them is much lower.
Edited By SillyOldDuffer on 27/11/2017 09:18:03
