Preventing distortion.
Home › Forums › Beginners questions › Preventing distortion.
  • #436898
    Simon Lee 2
      @simonlee2
      I have to cut a full length key way in a metre long by thirteen millimetre piece of EN24 round bar. The cut isn't a problem, but I am concerned that the bar will bend horribly when the stress is relieved assymetricaly. Is there any way of stopping it, or correcting it? Thanks, So.
      #9929
      Simon Lee 2
        @simonlee2
        #436900
        Anonymous
          Depends upon the exact material spec. If it's EN24T then it's hardened and tempered so has already been stress relieved to some extent.
          #436966
          Zan
            @zan
            The late great John Stevenson showed us how to straighten a bent lead screw with a lever in his badgers workshop posts. So correcting any bend shouldn’t be too difficult, but it all depends on the exact material spec as Andrew says, and also the function of the part.
            Todays update from Bodgers Lodge
            Search for this thread, Long, but interesting reading
            Edited By Zan on 12/11/2019 13:41:56
            #436980
            Martin Kyte
              @martinkyte99762
              Cut another keyway on the oposite side.
              regards Martin
              #437009
              not done it yet
                @notdoneityet
                Posted by Martin Kyte on 12/11/2019 14:38:38:
                regards Martin
                Likely only need to cut the stressed skin of the shaft. Keith Fenner on utube manages t straighten bent shafts quite well. Likely others.
                #438800
                Simon Lee 2
                  @simonlee2
                  Righty ho, vee blocks and a lead hammer it is then. Thank you all.
                  #438825
                  not done it yet
                    @notdoneityet
                    Posted by Simon Lee 2 on 25/11/2019 22:41:17:
                    That’s not prevention, it’s recovery!
