Hi,
Two years ago I purchased a Sieg SX3L Mill and also purchased the then new version of the Sieg X axis power feed.
See my message above I posted just after I purchased the mill from Ausee.com.au in Melbourne, Vic, Australia.
In the early days of using the SX3L I had intermittent problems with the X axis power drive clutch which connected motor to the X axis lead screw, the clutch was jumping out of engagement,
I made some measurements and found out the clutch only had a 1mm engagement, I called Ausee.com.au and explained the problem I was having with the SX3L clutch. They contacted Sieg HQ in China, It turned out the wrong part had been supplied with the Sieg X axis power feed.
Sieg HQ supplied the correct part which had a extra 4mm of engagement over the old one, a week or so later it arrived via courier, and I soon had it fitted, that was over two years ago.
I am VERY pleased with the Sieg X axis power feed and my SX3L mill, Ausee.com.au provided great service.
The X axis power feed has saved me from many hours of hand wheel cranking.
I am now working on driving the Z-Axis hand crank with a NEMA 23 Stepper motor, 3.0Nm(425oz.in), 10mm shaft
Ray (Brisbane, Australia)
Edited By Ray Creighton on 22/09/2018 13:33:42
