Has it jammed because you have wound the cross slide out too far and the lead screw has become disengaged and you can't wind it back in?
If so, you can restore normal operations by trying to wind in the cross slide and at the same time winding the leadscrew handle forwards and backwards maybe half a turn each way. It may well take several attempts, but it will eventually go.
The Emerald Isle
Edited By steamdave on 07/12/2018 16:22:55
