poor engineering companys
Home › Forums › Beginners questions › poor engineering companys
Viewing 13 posts - 26 through 38 (of 38 total)
  • #167367
    John McNamara
      @johnmcnamara74883
      Gee Guys….
      In this thread earlier I mentioned a V12 Aero engine and no one picked up on it.
      #167371
      Involute Curve
        @involutecurve
        I can do it but I'm quite a bit north of you, having said that I've done loads of stuff for bikers via drawings / emails photo's etc, so it can be done but it can also take more time due to communications delays, CNC is really aimed at production, however most of the stuff I make are one off's, I work from home so my overheads are small and my time is my own, I perhaps should point out I'm not commercial as a rule I only do my own and mates stuff, but if your stuck and time is not your main priority Ill have a look.
        Shaun
        #167372
        derek blake
          @derekblake72550
          Thanks Shaun
          Thats very kind, im in no mayor rush to be honest, if i know its getting done sometime id be happy.
          #167376
          norman valentine
            @normanvalentine78682
            Gosh, I hadn't realised how lucky I have been. I recently completed the building of a vertical milling machine from castings that I made myself. There were two jobs that I could not do so I went to a local company, Adams Engineering, Skegness. They milled a flat surface on an aluminium casting 24" x 3" and threaded the end of a 16mm splined shaft. Their work was spot on and not expensive.
            There are people out there that can do jobs at realistic prices, you just have to search for them.
            #167378
            John McNamara
              @johnmcnamara74883
              Hello Norman
              Great to see a self built mill.
                One of the problems with subbing out the work is you will very soon have spent a lot more on the model than it is really worth if you are not careful. Most of us in our own workshops would not be able to produce reversing link, ecc rods etc in less than a day so if I were charging my daily rate that would be over £325 with the VAT and thats without any materials or tooling costs. Don't forget that the part that took 20mins to make may need a 30min round trip to the postoffice to be weighed and posted
                Or a whole traction engine would take over 1000hrs work, even at minimum wage it won't be worth that for a 2" let alone the 5 to 6 times that you will be paying for skilled work.
                I do take on the odd commission but its whole engines where I can make one part to fit another, no good saying you want a bush with a 1/2" hole and 3/4" OD if your shaft is a bit of BMS thats 0.003" undersize and the gears are a thou or two over the 3/4" bore if you want to press in the bush. manual or CNC will make no difference without the mating part.
                Has Graham actually got your castings? if so I would go and collect. More likely they are not cast.
                #167388
                derek blake
                  @derekblake72550
                  Im going to by a mini mill and do what i can myself, he has my money and my parts but i don't drive so i have to just ring and email.
                  which hes ignoring both..i'm seriously angry and i'm not the type of person to be messed around with.
                  #167390
                    Posted by John McNamara on 22/10/2014 14:02:54:
                    Gee Guys….
                    Nice engine and so are the little diesels and glows but as the thread is about getting parts machined I think most people took little notice as postage from the UK to Oz and back would not be practical. If you want to discuss the V12 then may be better to start a thread in teh IC engines section.
                    J
                    Edited By JasonB on 22/10/2014 17:11:39
                    #167391
                    Oompa Lumpa
                      @oompalumpa34302
                      Posted by JasonB on 22/10/2014 17:10:31:
                      You are quite right it might not be practical Jason, but I can guarantee it will be four times the cost of the part as well. Postage in Australia is a real dear do.
                      I have learned over the years that it is far better to have the item in front of you that needs the part rather than someone send a drawing. There are only a few people who send me drawings that are any good. The rest are "variable". Mostly it is all hand fettling to make vintage stuff fit together properly.
                      graham.
                      #167392
                      Manofkent
                        @manofkent
                        Derek. I see you plan to purchase a mini mill soon. I bought a proxxon now mf70 for some small bits I wanted to make (I also have a "normal" mill), but got a CNC conversion kit as well. I wouldn't be without it now. All those tricky shapes like expansion links, connecting rods etc are so easy now. Just a thought.
                        #167393
                        derek blake
                          @derekblake72550
                          Thanks John, so I have found someone to do my bits then! Only joking, thanks for the info I shall look at a machine once saved up.
                          I don't think I'm going to see my money or my castings I've brought, so don't want to fork out for a mill yet.
                          #167396
                          jason udall
                            @jasonudall57142
                            When I worked in cnc turning shop..
                            Minimum costs for and job was about 180 quid… unless done completely as favour..
                            These costs were. .
                            Quote processing
                            Quality requirements assessment
                            Validation of customer credit
                            Sourcing minimum quality of material…
                            Special tooling
                            Special gauging
                            Last but not least cycle time…times number of parts
                            We oftern offered these customers..
                            180 quid for 1 or
                            180 quid for however many we could make out of 10 foot of bar. ..
                            Seriously it cost us as much to quote for 1 off as to quote for 14k parts..
                            Best approach was catch boss in right mood at get permission to get a machinist to make it for tea money….
                            #167419
                            jason udall
                              @jasonudall57142
                              Oops the above should have read
                              ..sourcing minimun QUANTITY of material. ….
                              Maybe I should read my posts….
