I did contact the gent in Australia who very kindly replied but of course as the rules for the construction of boilers are different over there this remains a problem.
I don't know if the book covers this, but the cylindriical part of Rocket's boiler is a separate construction from the firebox, the two being joined by circulation tubes. Stephenson must have been wary of the chances of getting the water tubes tight if one end had to be worked from inside the firebox.
If I recall the Japanese mass-produced version (OC?) had the boiler made in two parts as per the original, and I assume was accpetable to British boiler inspectors.
Rocket ought to be a reasonable hauler in 7 1/4" – not huge trains, but the boiler in 3 1/2" gauge would be about the same size as Tich, so eight time the volume, it should be able to pull several folks, even allowing for the larger wheel diameter and single wheel arrangement.
Edited By Stub Mandrel on 16/03/2013 13:15:42
