Planer Blades
Planer Blades
Home › Forums › Workshop Tools and Tooling › Planer Blades
  • #520898
    Clive B 1
      @cliveb1
      Hi Guys
      I’m after some cutter blades for an old Kity Planer Thicknesser, they are single sided 260mm x 20mm x 2.5mm.
      On having a look around I’ve seen some listed as HSS and others as being T1 HSS 18%W, without getting into it too deeply, what’s the difference between these two steels and would it be worth buying one over the other?
      Of course I would like some tungsten carbide ones but they are a bit pricey?
      Thanks to anyone who can shed some light
      #20113
      Clive B 1
        @cliveb1
        #520904
        not done it yet
          @notdoneityet
          I would think times between sharpening is the difference. The obvious difference is that extra ~12% Tungsten in the T1.
          TC blades are good but I would guess that chips can be expensive to clean up (apart from that initial cost!).
          I found that blades could last weeks between sharpening (with a regular honing) or perhaps only days (or less!) on iroko (or particularly with teak).
          #520936
          larry phelan 1
            @larryphelan1
            Ever try working on hard maple ?sad
            #520941
            Bo’sun
              @bosun58570
              I'd stick with HSS rather than TC unless you are machining especially hard timbers and can be sure the timber is free of debris (nails, stones, etc) . A chipped HSS blade is much cheaper to salvage than TC.
              I use HSS on my Kity 1637 to good effect, keeping two spare sets so that I can continue to work while chipped blades are reground.
              My last blade purchase was from "Woodford Woodworking Machinery & Tooling" at a very reasonable price.
              I haven't researched, but I suspect segmented spiral cutter blocks aren't available for old KITY machines?
              #520944
                HSS is just a generic description of a family of tool-steels. Means very little other than it's not carbon steel – usually a good thing.
                T1 identifies a particular member of the High Speed Steel family, so the description is more complete, which is a plus. However, T1 is the usual general purpose HSS used for wood and metalwork for planer blades, twist drills, taps, dies, reamers, and lathe cutters etc. Not the toughest or most heat-proof HSS available for specialist work, but a decent performer. There's a good chance anything just described as 'HSS' is T1, though the metal could be less reputable.
                peak4
                  @peak4
                  I don't know if you've looked on ebay, but there's a firm in Stockport which lists at least two types at slightly different prices under different trader's names. The two types have different MPN (stock) numbers 2kitCOM & 2kitS1
                  Both seem to be the same company.
                  They also list the same size under different machine manes, so have a good browse around there.
                  Bill
                  #520974
                  not done it yet
                    @notdoneityet
                    Posted by larry phelan 1 on 19/01/2021 09:55:40:
                    Timbers with a high silica content are the ones that wreak havoc with planer blades.
                    #521162
                    Clive B 1
                      @cliveb1
                      Thanks for the reply’s guys
                      It definitely won’t be tungsten blades as said they are a lot harder to rectify if they get chipped.
                      Bo’sun just before doing this post I did come across the woodfordtooling.com website
                      which states they do Kity 1637/637/636 Planer Blades 260 X 20 X 2.5mm One Pair
                      £10.89 in High Speed Steel.
                      Strange thing is they resharpen Planer Blades 260 X 20 X 2.5mm for £15.49 a pair, am I missing something here dont know
                      Another site I looked on was knife-point.co.uk and prime-tooling.co.uk both priced at £16.99 and both saying T1 HSS 18%W Quality, hence my reason for coming on the forum just to check if there is likely to be any difference the two steels ie. woodfordtooling or the ones offering the T1 HSS.
                      Bo’sun, you are talking some serious cash for segmental spiral cutter blocks, I was looking to find out how to replace the cutter block bearings on my machine and I came across this video
                      which makes very interesting viewing for anyone who has a Kity 636.
                      Peak4
                      I tried doing a Google search using 2kitCOM & 2kitS1 and didn’t have any luck, can I ask what their website is?
                      Not done it yet
                      No, never tried machining hard maple and timbers with high silica content, you say it wreaks havoc with planers blades, I assume you have machined such a wood, so what was your solution to problem?
                      Just keep sharpening the blades laugh
                      #521163
                      Clive B 1
                        @cliveb1
                        #521194
                        not done it yet
                          @notdoneityet
                          Not done it yet
                          Get them resharpened is always the answer, if honing is insufficient to return a good cutting edge. When I used a planer regularly, the local sharpening service called in weekly or about every couple of weeks, if phoned, as I recall. That was about 30 years ago… I expect things have changed in the interim.
                          #521196
                            I've not found hard maple to blunt the blades, main problem is the wide chips that come off that want to block the extraction. As NDY say it's the silica in some of the hardwoods that blunts the blades you can often see the fine white lines in the grain of teak.
                            My Kity uses double sides 1.5mm thick blades in a carrier that work out quite economic and I usually just replace ones dull or maybe hone once before fitting new.
                            #521206
                            Speedy Builder5
                              @speedybuilder5
                              Grand Designs the other night (Dave ??) guy building house in the UK Japanese style, wanted to use Japanese Spruce. Apparently that blunted saw and planer blades 3x as fast as Scandanavian spruce but its strength was more than double that of Sc Spruce.
                              #521224
                              Bo’sun
                                @bosun58570
                                Posted by Clive B 1 on 19/01/2021 22:17:09:
                                Yes Clive, they are a considerable investment, but if you do enough work with them, they may well pay their way. At least if you hit something hard, you don't wreck each blade, and only have to index the inserts and you're back in business.
                                They are also said to produce a better finish. I guess the spiral design eliminates the corrugated finish from poorly adjusted blades.
                                #521292
                                peak4
                                  @peak4
                                  Peak4
                                  Seems to be the same Woodford outfit in Stockport
                                  Link 1 2602025-2KITCOM
                                  Link 2 2602025-2KITS1
                                  Bill
                                  #521294
                                    I get mu thin ones from them and they seem to last longer than the original Kity items did
                                    #521305
                                    Bo’sun
                                      @bosun58570
                                      Good afternoon,
                                      Sorry to sidetrack a little, but as there seems to be some KITY owners here, any idea if spares are still available? I seem to recall hearing that Sheppach may be involved. Not that I need anything (yet), but it seemed a good idea to ask.
                                      #521624
                                      Clive B 1
                                        @cliveb1
                                        Spares, the only items I’ve purchased are planer blades, mine being the single sided ones.
                                        I’ve just bought some Fag bearings for it from bearing-king.co.uk.
                                        I also needed some very small springs, they are the ones which live under the planer blades which keep the blade pushed up when setting up ie. they stop them from dropping down into the bottom of the slot in the cutter block which helps during setup, I bought them from a place called flexosprings.com although they do have a minimum order charge of £9.
                                        I did buy some off ebay previously but they were too strong so no use.
                                        If its metal shafts and the like I usually come on this forum knowing someone will own a metal turning lathe which I don’t possess and sort something out pricewise and ask them to do the turning work for me.
                                        I can’t remember who I last bought drive belts from but I do remember the guy made them up for me.
                                        Mine are all flat ones and my Kity has the motor in the middle of the table with the machines bolted on around it, so if the belts were slightly too long I can just slide whichever machine away from the motor to give it the correct amount tension.
                                        I’ve changed how the switch use to live on top of the motor as I decided it was time, I stopped leaning over whirling machines in order to switch it off.
                                        Also because of limited space where the machine is, I fitted four braked castors to the table because it was getting a bit of a maul for me to hump the machine about because the rear wheels did not swivel, they only use to roll backwards or follows ie. no swivel.
                                        As far as any other parts, someone did suggest nmatools.co.uk but to be honest I’ve never tried them.
