Posted by Michael Gilligan on 02/09/2019 22:36:52:
Posted by Michael Gilligan on 01/09/2019 18:55:19:
… I'm going to a meeting tomorrow evening, and will ask the group.
Sorry, Steve … I drew a blank
No-one at the meeting knew the specification of the raw wire used for making Blue Pivot Steel
One chap was pretty sure that he remembered it being 0.8% Carbon: which is consistent with the general specification 'High Carbon' but doesn't really get us very far.
What they did all agree was:
"the modern stuff is rubbish; too much re-cycled material in it"
That may be an over-generalisation, but the consensus was:
"grab any vintage stock that you find … they don't make it like that any more"
Edited By Michael Gilligan on 02/09/2019 22:41:22
Really annoying because I can't find the reference. (It's not in the book I thought it was.) However, from fairy recent memory the composition of 'Blue Pivot Steel' is nothing special – it's just a spring steel as used to make Piano Wire. What is different is the way it's hardened – Pivot Steel is softer than most Piano wire, which is made very hard and strong by a combination of drawing and heat treatment.
Old chaps like to believe modern steel is inferior due to recycled material or because Johnny Foreigner is incompetent. Due to the way steel is manufactured both are unlikely! Steel isn't made by stirring oddments in a pot and hoping for the best, rather the chemistry is well understood and steel plants are carefully managed and highly automated. The only contaminant I know of that can't be removed is radioactivity due to Nuclear Testing. Inclusions are far more likely to be bits of corroded furnace wall than undissolved ball-bearings!
I suspect what causes disappointment isn't a quality issue as such. My guess is an ordinary soft Piano Wire is being sold as 'Blue Pivot Steel' when it hasn't been fully processed as was done in the past. That may be because Blue Pivot Steel as preferred by traditional clockmakers has become a low-demand niche product and no-one today finds it worth their while to make it properly for general sale. I suspect modern wire sold as Blue Pivot is chemically similar to old-stock but isn't actually equally 'fit for purpose', too gritty.
