Yesss – or you may have rings which are too thick. You only need about .050 D-d.to give the right wall pressure which is not a lot.
If you go into the Model Engineers Handbook section 11.5 its is all covered. The problem is that to get the thickness you have to resolve a bit of an equation. One of the few times that TC wasn’t all that helpful because it doesn’t have wall pressure and thickness in the right places.. It isn’t in fact more than O level arithmetic, but if one is a bit out of practise one might have to think about it..
Alternatively a very nice gent called Allan Beasley set it all out in 2 articles ME 29/4/2009. All you have to do is read the info off his charts, so well done him. Couldn’t be easier. His second article tells you how to make your own.
Alternatively, you can just send off to Stuart Models, because the rings they supply are to the Tubal Cain/Prof Chaddock low wall pressure low friction thickness – or the 3 sets that I have bought have been.So I haven’t honed anything – just a good tool finish, set a couple of thou gap and both engines (3 cylinders) whirred away like gooduns. Other ppeople may supply the same or similar rigns, but I haven’t done the maths for them so I don’t know. Those are iron rings – the formulae for iron or brnze rngs are hte same but hte vlues to be plugged in are different – see ME Handbook.
Check the gaps of course, and check the difference between the free gap and the installed gap. You are, for a steam engine looking for a ratio of d/10 installed to free gaps.
Well worth checking to get it right. Because of the maths very small differences in section of a ring make a great deal of difference to the wall pressure and hence base friction, and thats before the gas gets round the back of the ring and starts to make it seal. So its worth trying to understand the situation and getting it right.
Edited By mgj on 25/03/2011 18:39:50
