Posted by Michael Gilligan on 18/06/2015 22:10:47:
Posted by Izack Madd on 18/06/2015 21:19:34:
I'm really hopeful there is an simpler way as it's sort of the thing I can image engineers might do such as cotter pins. But then again it's also the sort of thing that engineers would make themselves
A miniature version of a chain link extractor is probably what you need.
Edited By Michael Gilligan on 18/06/2015 22:13:38
Having looked at this device.
If I take a block of…? Drill a hole the right size for the pin, cut a notch out that transepts the hole midway. Widen the top half of the hole. And epoxy a nut in the notch and get a wing bolt. File the tip down to just fit through the hole so as its less likely to snap or wander. The pin will locate in the small drilled hole. The filed wing bolt will locate, I hope, automatically and pop the pin out and if I put a second notch after the first the pins should push each other through.
Great plan Batman. Or should I say Michael…
This what I love about you lot while the answer may not be out there as we are from differing field ideas spring forth. Thanks to all.
