pillar drill column
pillar drill column
Home Forums Beginners questions pillar drill column
  • #108849
    Ian Parkin
      @ianparkin39383
      I need a new length of steel for my startrite pillar drill column 1.5 metres long would be fine
      it needs to be 2 3/4 " diameter
      any suggestions on where to source such material and will it need grinding to size or will bright drawn be ok wall thickness is 4mm or thereabouts
      Ian
      Ian Parkin
        @ianparkin39383
        #108856
        NJH
          @njh
          Hi Ian
          M Machine Metals list a 2.75"dia x 1/4" wall steel tube here ……………
          SIT DOWN NOW……
          AT £27 PER 300mm !!!!
          Good luck!
          Norman
          #108861
          Ian Parkin
            @ianparkin39383
            Thanks for that they only want £30 for solid steel (per 12&quot
            would bright drawn be ok? what would the tolerance be on diameter?
            any body got any idea where to get some cheaper ( scrap) from?
            #108863
            David Colwill
              @davidcolwill19261
              You could try searching "seemless hydraulic tube" and see if you can find someone near you.
              jason udall
                @jasonudall57142
                Schaffold tube? and bushes?
                #108870
                Phil H 1
                  @philh1
                  Ian,
                  Just out of interest – what happened to the orginal. If it is just rust? You might be surprised how well you can recover it. I had to do a lot of work to retrieve my drilling machine and lathe cabinet.
                  PhilH
                  #108871
                  Old Elan
                    @oldelan
                    Ian
                    Have you tried these guys? http://www.machinespares.net/document-library/select-machine-type.php?brand_id=1 They do Startrite spares.
                    Although they have no 'to buy' on the column they may be able to source one for you. Probably not cheap either, though….
                    #108882
                    Ian Parkin
                      @ianparkin39383
                      I bought the machine and someone had modified it to a large throat by chopping the column and extending the head out by 24" or so
                      Ive welded it back together but would really like a longer column a s the startrite has a tall base casting and the head has a 2 speed epicyclic gearbox on it as well so room under the chuck is limited
                      I'll have to trawl the scrap yards round sheffield for a length…the reason or my post was what sort of steel finish do I need to allow the table to move and clamp well……is bright drawn solid OK or is seamless tube OK or does every type need to be ground to 2 3/4 "
                      #108916
                      Ziggar
                        @ziggar
                        Posted by jason udall on 16/01/2013 13:30:41:
                        got to agree with this
                        find some scaffolders iin the area and give them a couple of quid for a length appropriate to your needs
                        then bush it up to your hearts content
                        jobs a good'un
                        most scaffold tubes are 47mm and galvonised
                        Edited By Ziggar on 16/01/2013 18:55:33
                        #108922
                        David Jupp
                          @davidjupp51506
                          There will be a HUGE difference in stiffness between scaffold tube and 2 3/4" steel tube (especially if you get ally scaffold tube). They didn't use a column of that diameter originally just for fun.
                          #108962
                          jason udall
                            @jasonudall57142
                            Posted by David Jupp on 16/01/2013 19:27:07:
                            Good point not least with 70 mm solid vs 47 mm od tube…
                            But would it be stiff ENOUGH?…
                            while we think about that. What would be the consequence of a longer pillar (say double) of the original section be ,to the machines STIFFNESS?
                            #108964
                            JohnF
                              @johnf59703
                              Try a supplier of hydraulic ram material or maybe look for a scrap one, it is chrome plated and very accurate for size. Don't worry about cutting through the chrome you can nick it with a grinder then it will cut with a saw.
                              #108965
                              Lathejack
                                @lathejack
                                Hello Ian
                                Bright drawn bar will be fine if you can get it at the right price. It is formed straight and round but the surface finish can vary between batches. It is also usually a few thou or more undersize, but this can also vary.
                                We use bright drawn bar at work and i have once had to use undersize 70 mm bar where 2 3/4 was needed as it was a better fit than the undersize 2 3/4 bar we had. If you wish i can ask them to give me a price for the length you want, i don't live very far from Sheffield.
                                Seam welded steel tube isn't always formed very round, at least not for a good reliable fit in the bore of your drill head and table casting, with or without a bush.
                                Scaffold tube to me just seems too rough and flimsy as a replacement. You might find the table and head being pushed away from each other as the column flexes when using the larger drills that your backgeared drill head can manage. If you are not careful you might just end up with a rubbish drill.
                                I have an Elliot Progress 2G backgeared pillar drill that uses a solid ground steel column of similar diameter to yours, as standard, sat on a tall square cast iron column. I have often thought about using bright drawn bar of the same overall length so that the table can be lowered further to gain more room under the head.
                                 I will also have a look and see if we have an old hydraulic ram, as JohnF suggests, lying about.
                                All the best
                                Edited By Lathejack on 17/01/2013 01:49:15
                                #108966
                                David Littlewood
                                  @davidlittlewood51847
                                  Jason,
                                  The deflection of a solid round beam fixed at one end and loaded at the other is proportional to L^3, so doubling its length will increase the deflection by a factor of 8.
                                  The formula is Y = 64*F*L^3/(3*pi*D^4) where Y is deflection, F is applied force, L is length and D is diameter.
                                  For a hollow round beam, replace D^4 with (D^4 – d^4) where D is outside diameter and d is inside diameter.
                                  The formula is different for other cross sections; a Google search should lead to the answer for anyone interested.
                                  Incidentally, this shows why (a) stub length drills are so much stiffer than standard length ones, and (b) it's always worth swapping your small boring tool for one of even slightly greater diameter as soon as it will fit the hole.
                                  David
                                  Edited By David Littlewood on 17/01/2013 01:46:09
                                  #108982
                                  Ian S C
                                    @iansc
                                    If you get tube I think you should get at least twice as thick as the 4 mm you suggest, particulary if you are going to extend the length, you want ridgidity, and minimum vibration. I,d be looking for old hydraulic cylinder, or ram of suitable size, with any luck the ram might be straight, If its over size, you might need to borrow a bigger lathe. Ian S C
                                    #108986
                                    Ian Parkin
                                      @ianparkin39383
                                      Thanks for all your replies
                                      I would not consider using scaffold tube far too flimsy and rough surface finish to take the table and be able to move it
                                      I was only wanting an increase in length of about 6-12 inches over what i have available now
                                      Lathejack if you do find an old ram I look forward to hearing from you
                                      Ian
                                      #108994
                                      Gordon W
                                        @gordonw
                                        If you do find a piece of tube with the correct outside dia. but thin wall ,it would be worth filling it with concrete, maybe with a wire or two for added strength.
                                        #109004
                                        Peter G. Shaw
                                          @peterg-shaw75338
                                          Alex Weiss in ME 07 Apr 1995 page 434 extended a NuTool DIY13 by 100mm/4inch using a piece of scaffold tube.
                                          I have used his idea on a NuTool CH10 but had to use a solid extension piece due to the difference in column size.
                                          Peter G. Shaw
                                          #109005
                                          Michael Cox 1
                                            @michaelcox1
                                            I have extended my pillar drill by 150 mm, see **LINK**
