Pattern Makers Vice
Pattern Makers Vice
Home Forums The Tea Room Pattern Makers Vice
  • #805532
    Vic
      @vic
      I’ve never seen one of these before.
      https://youtube.com/shorts/fMWH-ocY31k?si=_Mt4-9-6eXpil7k7
        Nifty bit of kit !
        Edit: … and whoopee !!
        There’s a patent
        https://www.datamp.org/patents/displayPatent.php?pn=457710&id=10443
        #805542
        peak4
          @peak4
          I’ve always fancied on of their other models, but never found one I could afford/justify
          Bill
          #805543
          Speedy Builder5
            @speedybuilder5
            I worked in the pattern makers shop during my apprenticeship for Vickers Armstrongs Aircraft back in the ’60s – never saw one of those,  plenty of contraction rules for different metals though.
            Bob
            #805549
            noel shelley
              @noelshelley55608
              That’s a neat bit of kit ! Though ONLY for wood, never seen one before. I would expect it to be rather expensive ? Noel.
              #805570
              peak4
                @peak4
                Start saving up now; reproductions seem to be available
                https://www.mprime.com/Emmert/forsaleCS.htm
                Bill
                #805650
                KEITH BEAUMONT
                  @keithbeaumont45476
                  Looks to me as if it is meant for the Maintainance Workshop of an Engineering manufacturer.
                  Cant see it ever being of use in any of the Pattern shops I have worked in ,or visited.
                  Typical, over engineered, “catch all” tool that 90% of it will not get used more than a few times. if ever.
                  Keith.
                  #805651
                    They have been a popular woodworkers vice here for a number of years particularly for those who also do a bit of carving or make more organically shaped furniture. Gets the work and the grain orientation where you want it so the chisel, spoke shave, etc can be used without too many contortions.
                    Probably not been seen by the UK members in a pattern shop as they are an American item. Bit like Pony clamps which were not seen here until 30 or so years ago as everyone just used sash clamps.
                    Axminster sold them for a number of years as well as some of the other specialist woodworking tool suppliers.
                    Spot the vice in this US pattern shop making patterns for full size locos, goor range of flywheel castings too.
                    #805672
                    KEITH BEAUMONT
                      @keithbeaumont45476
                      I have one of those multi angled wood carvers vices under the bench.It does as you say, orientates the grain whre you need it to be. It is nothing like those  massive chunks of cast iron in the Video.
                      Keith.
                      Things were a bit slow logging in tonight,
