Passenger carriage
Passenger carriage
Home › Forums › Locomotives › Passenger carriage
  • #1282
    Rod Ashton
      @rodashton53132
      Details
      #152912
      Rod Ashton
        @rodashton53132
        Looking for guidance to build an approx. 4` long passenger carriage.
        Have substantial pair of pivoted double bogies. Would like help on superstructure bracing for load bearing. Size of m/s angle or box section etc.
        A photo from underside would be appreciated as will happily reverse engineer.
        #152916
        Ady1
          @ady1
          Not many articles on passenger trucks considering the amount of passenger carrying ME folk do
          2726 and 2408
          Apparently Henry Greenly did an article with drawings in the Dec 3 1908 issue
          #152999
          Rod Ashton
            @rodashton53132
            Would anyone have access to the info. that Ady1 suggests, and be willing to share please?
            #153002
            Bob Brown 1
              @bobbrown1
              I did find this **LINK** which may help.
              It will need Microsoft Word if you have trouble with opening it let me know (PM) as I have converted it to a PDF
              Bob
              #153018
              Bazyle
                @bazyle
                I like the end pieces on the link supplied by bob. We have to have thick rubber mat over the couplings on our club ones. 1/4 ply box section will be pretty strong for most use unless you have some 18 stone passengers.
                I also recommend the lifting handles and suggest light springs (bungee rope) to align the bogies fore and aft when lifting onto track.
                #153019
                Flying Fifer
                  @flyingfifer
                  There is an article Building a 5" gauge passenger coach it starts in ME Vol 175 issue 4007 & goes on for a total of 18 articles the last being Vol 178 issue 4041. Sorry I can`t help other than this as I disposed of most of my back copies. I seem to remember it was pretty well detailed as a coach but was also suitable a a ride on vehicle.
                  Hope this helps. Have a look on Colin Usher`s site it gives all the issues.
                  Alan
                  #153021
                  Bob Brown 1
                    @bobbrown1
                    We have a flexible section that loosely joins the carriages right around the ends, to stop little hands from going between the carriages. Not sure where the 1/4 ply box section comes, from typo? the author used 1/2", if you are in the UK then B and Q sell 12mm WBP plywood and the larger stores can cut it to size for you.
                    #153043
                      I wanted a 2" strip cut off the edge of a 24" ply board for a benchtop.
                      "Sorry we can't cut smaller than 9" for H&S reasons."
                      "But it's the big bit I need making smaller!"
                      "That's OK then."
                      Naturally I took away both bits. The offcut has made a nice trough at the back for hiding cables etc. in. I just need to make a lid for it.
                      Rod Ashton
                        @rodashton53132
                        Gentlemen – Thanks for the replies. Extreamly helpful.
                        #153347
                        FMES
                          @fmes
                          Rod, I was rummaging around in the workshop yesterday and came across a copy of a Model Engineer article on making club trollies, its umpteen pages long and a bit worse for wear (we use it as our standard club design) but if its any use I can scan it in for you.
                          Lofty
                          #153350
                          Rod Ashton
                            @rodashton53132
                            Lofty
                            Would be very pleased to accept your offer.
                            Thanks
                            Rod
                            #153376
                            FMES
                              @fmes
                              Rod, please check your messages.
                            Home › Forums › Locomotives › Topics
