Posted by Mick B1 on 09/03/2020 18:04:07:
Posted by Robert Atkinson 2 on 09/03/2020 16:58:46:
Posted by not done it yet on 08/03/2020 10:17:46:
… I knew a fellow that removed the lead from a 12 gauge cartridge and fired it off as a ‘better’ November 5th banger. Worked well. The second attempt blew the gun apart. Attributed to a wad left in the barrel.
… patently spurious. … charge in a cartridge is enough to eject shot and wad from the barrel …
Not sure about that. It's reasonably common for a projectile that's too light for a given burn-rate of propellant to result in incomplete combustion of the charge. Results of a followup shot could be unpredictable … but there is a condition known as 'detonation' where a quantity of propellant is distributed through a space in a manner that generates a shockwave … Effectively the dispersed charge behaves like a high, rather than a low explosive.
This one's a puzzle that got me thinking about cause and effect.
Unfortunately, the evidence is incomplete. We don't know how the cartridge was modified, or the circumstances in which it was fired, or which part of the gun broke. Perhaps NDIY can provide more detail?
Where the gun broke is relevant because thats the point at which pressure over-stressed the barrel – an important clue. In normal operation maximum pressure is at the breech. Thereafter it must drop along the length of the barrel and fall to zero just outside the muzzle.
- If the gun failed at the breech, the cartridge is suspect.
- If the gun failed further along the barrel, an obstruction is suspect. (Though I explain later that air alone might be sufficient obstruction.)
The circumstances are relevant because there's a hint of revelry in this story! Gun fired as a Banger, Hmm?
Celebrations often involve carelessness, and diminished responsibility. During the high-jinks, maybe the muzzle picked up mud, or a twig, or Mr Anonymous popped a real banger down the barrel for a laugh. The owner may have believed his blank cartridge made the gun safe, and didn't check before firing it.
The cartridge has to be considered too. Maybe the lead shot was replaced with more powder, even something unwise like firework gunpowder. Or a gap was left between two wads.
I first assumed removing shot from a cartridge would automatically reduce pressure in the gun. Common sense suggests more pressure is developed pushing a load than moving gas down an empty tube. However I have a low opinion of 'common sense', and this might be an example.
The gun is powered by a chemical reaction turning a solid into a gas, also producing heat greatly expanding the gas. It does so at a speed related to the chemistry, barrel volume, and work done moving the shot.
Converting heat to work follows the usual heat engine rules. Heat converts into kinetic energy, accelerating the lead-shot. Conversion cools the gas greatly and thus reduces pressure in the gun. If a gun is fired without a load, it will get much hotter, hence the pressure may be higher too. Worse if the charge also burns faster than normal.
As the reaction is faster than the speed of sound, air inside the barrel acts as a spring, causing waves to bounce inside the barrel, causing unusually high pressures at the point of reflection. If the reaction is much faster than the speed of sound, air behaves more like concrete – it can't get out of the way fast enough.
Shock-waves matter more than average pressure and explosive speeds are relevant. I imagine a sharp pulse of energy being applied to the barrel by the modified cartridge rather than the normal well-engineered expansion.
I suspect reflected pressure waves do most of the damage when a barrel is obstructed, rather than shot colliding mechanically with the blockage. If so not necessary for a barrel to be completely blocked to over-stress it: only enough to cause a reflection. At the point of reflection the reflected pressure adds to the existing pressure. If the metal's elastic limit at that point is exceeded, the barrel will break.
All conjecture, but I can just about see how firing the first blank might have cracked the gun at a particular point, and firing the second blank repeated the blow in the same place without a wad or other obstruction. (I agree they would turn a risk into a dead-cert.)
Ignorantly modifying cartridges could take a gun for a walk on the wild side. Mick's suggestion that the first blank left unburned powder in the barrel is also possible. Burning loose powder could also put abnormal pressure on a weak part of the barrel.
Proof testing consists of firing guns with an extra heavy charge? This only tests the breech end of the gun, which is made considerably stronger than the muzzle end of the barrel. Much less pressure will damage the thin end of a barrel, which may be what happened here. Guessing!
Joining the dots and could be wrong. All comments welcome!
