oversize ER16 collets
Home Forums Workshop Tools and Tooling oversize ER16 collets
  • #519766
    T.B
      @t-b-2
      Hi
      Can anyone tell me of a UK supplier for 12mm oversize ER16 collets
      Gloster Tools normally sell them but they are sold out and i'm struggling to find another supplier
      Thanks in advance
      T.B
        @t-b-2
        #519786
        Brian Wood
          @brianwood45127
          Why not upgrade to the next size ER 20?
          #519792
          T.B
            @t-b-2
            Posted by Brian Wood on 14/01/2021 15:35:21:
            Yes that would be an obvious solution , unfortunately it won't work for my application
            If theres no UK suppliers any info on overseas suppliers would be gratefully received
            #519819
            Roger B
              @rogerb61624
              These people have them, but I don't know if they can deliver to the UK at the moment.
              https://www.maschinen-werkzeuge.com/de/spannzange-er16-o-12mm.html
              #519949
              Rob McSweeney
                @robmcsweeney81205
                http://www.westontooling.co.uk have them listed at £20 each Doesn't necessarily mean they are in stock, of course.
                #520082
                John Reese
                  @johnreese12848
                  I have a metric set of ER32 collets. I also purchased a few inch sized collets. My tooling is almost entirely inch size. With 1/2" and 3/8" the metric collet when hand tightened will not hold these inch sizes tight enough to keep them from sliding out of the collet. That meant 3 hands were needed to chuck these sizes: one on the spindle brake, one on the collet wrench, and one to hold the end mill.
                  #520103
                    A simple cure for those that can't multitask is to slip the tool into the collet and bring the quill down until cutter rests on something and the right amount of tool is exposed then lock the quill. You can then tighten with two hands before unlocking the quill and allowing it to rise.
                    #520112
                    not done it yet
                      @notdoneityet
                      Posted by JasonB on 16/01/2021 07:07:06:
                      I can’t multi-task when three hands are required, so I have a couple of 2-4-6 (or maybe 1-3-5?) wooden blocks handy for propping up end mills/drills while tightening the collet chuck, for the bottom end of the collet’s range.
                      #520113
                      Nealeb
                        @nealeb
                        My CNC router spindle uses ER20, although I'm often using small shank cutters. I've found that by the time you've brought a 4-3mm collet down to grip a 1/8" (3.175mm) shank, you're working quite hard and you are not going to be able to tighten by hand enough to grip the cutter. Like a previous poster, I've bought a few imperial size collets to overcome the problem. Resting the cutter on a block is a good trick, though!
                        Sorry this doesn't help with finding oversize ER16 collets, though…
                        #521074
                        T.B
                          @t-b-2
                          Bit late back , but thank you for the heads up on possible suppliers
                          Collets hopefully now winging there way to me
