The Commer TS3 (Made in the Tilling Stevens factory in Maidenhead) was a three cylinder, scavenge blown, opposed piston two stroke diesel.
Supposedly,a lot of inspiration came from the Junkers Jumo
Each piston drove to a rocking lever, the lower end of which had another con rod on the crankshaft which was below the cylinders.
There was talk of a TS4 for the Admiralty, but don’t think that it ever came to fruition.
The Admiralty did use conventional Foden FD6 blown two strokes in some vessels.
And, of course, they used the Napier Deltic (An 18 cylinder two stroke with three 6 cylinder banks arranged in triangular form around the crankshaft)
As used to power the Deltic locomotives, two, each producing 1,650 bhp, were used.
The Rolls Royce K series engines, in 4, 5 and 6 cylinder forms were opposed piston two strokes.
The two crankshafts were connected by a train of gears. They were known as the “Peanut Butter Engines” because reputedly, they would run on it! The intention was that by disengaging one of the gears, one crankshaft could be moved relative to the other to adjust the compression ratio. (No doubt, this would also change the port timings). In this way the engine could run on whatever fuel could be found on the battlefield. (A M O D specification for the engines)
The test “bed” was a Dennis tractor unit used with its trailer to deliver parts, overnight from Crewe to Hythe Road in London. The transmission was a three speed Allison torque converter. Talking to the driver, they only ever used one ratio. “What’s it like on hills?” “What’s a hill?” (With 250 bhp available, no wonder) Reputedly, unladen, it could out accelerate a Jaguar from 0 – 30!
Being a scavenge blown two stroke, they were NOISY!
There is one in the Rolls Royce Heritage collection.
The larger Leyland L60 was a similar engine, intended for tanks.
