part 1….
Hope this dosn't encourage howl's of laughter or rage…..
I've traveled the world so much, moving house and workshops all time…but the next one will be my last…..
Reason for this post….
u'll also have dirty tin's and bottles all over the place taking up valuable room and gathering dust…….!!!!!!!!!!! and to bring this to a head Ive just found my mothers old sewing machine klick-clack oil can, which is just perfect for the lube points around the Student….which was a pain….
To reduce the amount of different types of lube…..make life easy and save space…..
a list of lube I now use….
apart from the WD''s of this world and not forgeting spray greace….
I now only use :-
1, 5-40 Synthetic engine oil for the car job and in the auto lube on the Bridgeport…
2, Mineral engine oil 15-40 for oil cans and the old cars, motorcycles…
3, chain saw blade oil for the chains but also used on bed screws on the bridge port…
WHAT U SAY……read on…..
initial lube after cleaning screws ( at least once per year, I do it over Christmas, keeps me out of the way, Bah humbug)….(knee and table) clean with aerosol brake cleaner…spray liberaly until the srew is clean wiping the worst off first then the dirty dippage – once clean and dry "the screws" use the oil on the screw, I just use a throw away paint brush—this oil behaves a bit like child snot…..just hangs there…not the same coulor tho….hahah….
actually this stuff is a mess to use as it has long chain mollecules so it appears very stringy and once it's on anything it dosn't drip..works great on the vertical as well…I also use it on my two post car lift screws, normal oil even 80-90 weight gearbox oil just throws off…..
4, Auto trans fluid, Dextron 3 or 4, used, well u get the idea but also the gearbox's on my Colchester student…..it behaves well when hot and cold plus it has an anti-frothing agent….
5, Grease the general high melting point type.
6, water pump grease…..
7, 2T, two-stroke oil……
8, 80-90 weight gear oil….and thats it….
