I use a sewing machine motor and pedal on a watchmaker's lathe, but it's a standby unit I use in France to save lugging a more powerful motor I use here, personally I'd avoid using one on the Simat, it's too heavy!
You'd get away with one for a while if using for short bouts of light duty work, but they certainly don't have enough grunt to run that lathe And cut metal as well, and you certainly won't be able to use the powered leadscrew!
Even on small turnings on a Boley 8mm, sewing machine motors get extremely hot fairly quickly and I'm on my second motor, you'll also get extremely frustrated by the limitations of what you will be able to do with it!
I have a simat 101 here and have just found the manual for it, once I get scans of it done, I'll happily Email a copy to you, I remember someone asking on here about the manual too but don't know where that thread is now!
Just remembered one issue with the Simat you'll need to be wary of, the entire topslide is secured by a single bolt for quite an overhang of metal!
When I got my lathe, I discovered under all the grot and paint that the topslide base had been broken across the bolt hole and badly repaired, i've since welded it and cleaned it up and is ok, but I won't be able to take liberties with it, it's certainly a very weak area to be aware of, so heavy cuts are best avoided if you do end up with a decent powerful motor!
John.
P.S. you got a good deal for 30 quid, well done, I paid around £40 for mine at a local auction a few years ago, I'm also fortunate that my lathe came with a Jacobs tailstock chuck and a 3 jaw SC scroll chuck with reversible jaws, which i also use if pushed on an 8mm adaptor when I need to turn bigger diameter stuff on my Boley,
I keep mulling over getting rid of the Simat, but the powered leadscrew, good solid cast iron bed plus it's capacity always win me over, if I could somehow make the topslide more beefy and adapt it to take a vertical milling unit, I'd probably get rid of my Unimat 3 by choice!
J.
Edited By RJW on 09/04/2013 08:48:06
