Without doing it as formally as Jason suggests, what he recommends is pretty much what I did when I first started my WM250V.
It was as much a matter of familiarising myself with the controls, with the sounds and feel of the lathe running. I fiddled with the headstock gear train too, to see how it was put together and how to get the backlash right.
After a few months' use, I took up the headstock bearings a little, and haven't touched them since.
Thing to avoid is engaging power feed when the slide can't move – the shearpins seem stronger than is ideal. About a month after installing the 250, I engaged the longitudinal feed when I meant crossfeed, against a hard-locked saddle. The shearpin held, everything got locked solid and the saddle drive pinion shaft got bent – the one that engages with the bed rack. Eventually I freed it off, and lived with the tight spot caused by the bent pinion for a year before I discovered how to straighten it with the tail of an ordinary crowbar…
No more trouble with that since. Nearly 3 years now, and in use most days – I wouldn't go back to the Myford I used to have.
Edited By Mick B1 on 23/02/2018 09:11:36
