Need advise please
Need advise please
Home › Forums › Beginners questions › Need advise please
  • #9039
    wayne larsen
      @waynelarsen80726
      Cl500 gearing
      #335961
      wayne larsen
        @waynelarsen80726
        Hello all I’m a Newby. Just bought my first lathe, could someone give me some advise on setting up the gearing as the manual is not clear. I’m trying to set it at 400rpm can someone varify what belt should be on what pully,a pic would be great. Thanks
        #335963
        JohnF
          @johnf59703
          Want, more info needed on your lathe, make model and a photo may be useful
          #335965
            Says it's a CL500 in the post's sub-title. Sorry I don't know that one but someone will.
            Welcome Wayne,
            #335968
              Welcome to the forum Wayne
              http://www.clarkeservice.co.uk/product_manuals/metalworking_lathes.shtml
              It looks like you need a belt on the largest pulley of the lower cluster to the smallest of the middle cluster, then a belt from the next smallest pulley on the middle cluster to the smallest pulley on the top cluster.
              There are some CL500 owners around here, hopefully one will pop in in a bit.
              mick70
                @mick70
                make sure you have right manual as when i bought mine manual was wrong.
                look at step pulley on motor behind the big pulley is a small one.
                unless you know its there you'll never realise.
                #335972
                mick70
                  @mick70
                  just looked at link and it as new manual on it.
                  another thing worth knowing is thread chart in manual is wrong go by one on rear guard inside.
                  #335980
                  richardandtracy
                    @richardandtracy
                    I have a CL430 & the Warco version of the CL500. (Just establishing a credential)
                    On the motor spindle in the belt box, there are 4 grooves on the pulley, put the belt on the smallest one nearest the motor, it's hidden behind the biggest pulley groove and almost rubs on the back of the belt box. Then the other end of that belt goes parallel to the box onto the biggest groove in the middle pulley. Then on the middle pulley put a second belt on the next biggest groove. The lathe spindle end of that belt, goes onto the smallest goove of the lathe spindle pulley.
                    If it's all too tight to fit the lathe belt, there is a motor position adjuster between the motor and the lathe bed.
                    Hope that helps,
                    Richard.
                    #335988
                    wayne larsen
                      @waynelarsen80726
                      Thanks for all the replies guys, I would not have found the small pulley hidden at the rear of the motor pulley. All up and running now. Just need to build a new bench for it now as it’s moving to much on this one. 🖒
