Posted by ray jones 1 on 07/01/2015 03:08:25:
I have acquired a brand new unused variable motor control unit that came off a Myford VMB Mill. There are no instructions or specifications with it… Before I connect it to a motor, I am trying to locate the original motor spec . thank you ray
No specific knowledge of that unit but if it's basically a repackaged Danfoss inverter you should be able to work out its specification by googling the model of the inverter. You may have to dismantle the outer casing of the unit to get to it, but it's pretty much 100% guaranteed that inside will be a bog standard inverter, could even be one from their current range or covered in their 'legacy literature'- at least the basic model/series name should be obvious.
Likely the inverter unit will have a nameplate of its own with HP/kW/voltage all clearly marked, but if not you can google the inverter name, download the literature for that series, and work out which exact model it is from its external dimensions – size will go up with horsepower.
In any case you will need the model name/series to download the manual for it – whatever settings Myford programmed in may not suit your set-up, and there's also a good chance the inverter may be able to display its own model number or other info which lets you determine its spec if all else fails, but you'll need the manual to work out how to get this info!
Edited By Bikepete on 07/01/2015 09:27:53
