Hi Ivy.
I have been following this post w.r.t. your gib screw problems on your Super 7.
Myford (the Beeston, Nottingham version) were not into making 'random' changes. I served my engineering apprenticeship there (68-74) and any changes to their products were very carefully controlled and recorded.
I feel that I can say with some certainty, that your counterbored holes are definitely non-standard, as to produce 4 counterbored holes are 4 extra machining operations, which is additional cost.
In addition to this, Myford policy was to use as many 'common' parts between all their machines as possible to benefit from the economies of mass production. So the ML7 and S7 saddles were probably the same part at that time your lathe was manufactured, so you probably have the correct gib screws as per original design intent.
With respect to your problem, it looks like it may be an owners modification. May I suggest that you undertake a detailed survey of your gib strip and the saddle holes. With this information you can design a set of bespoke gib screws to suit your saddle.
It seems as this may be the only way out for you.
I hope this helps
Alan
Edited By Alan Donovan on 17/03/2022 12:10:59
