This post is mainly addressed to Dennis, who is in posession of most of the correct facts.
I now have all the internal parts, bar one 16T gear from the main cluster bank, but this is on Myford's website, so I should be ok for that.
Now to re-cap, the right hand gears are 18T, 30T and 18T. I will have to get them specially made as at the moment as they are not available.
The 24/30T tumbler gear should be a 12/30T gear. Correct? I ask this as the tumbler gear as fitted to my lathe is a 20/30T, which is neither one nor the other, and the small gear is removeable and keyed , but I can't see a 12T fitting the same keyed shaft as the keyway would ,in my opinion break through the gear at the base line of the teeth. However the Tumbler gear on Myford's site (A 1974A/1 may well interchange which would solve the problem. The 20T gear is damaged anyway, so it has to be changed before long.
The detent pin is missing from the box lid and I would welcome any details of pin and spring so that I can turn something up to fit.
Now that I have the layshaft and gears, I can understand how the box functions and I will post some pictures with a "flow chart" later when I get a bit of spare time. As dennis points out I do have some way to go yet, but I am getting there,one piece at a time !!
Mike.
