Myford question
Myford question
Home Forums General Questions Myford question
  • #571022
    phillip burbank
      @phillipburbank45787
      Hello every one my first post on here, so please excuse my ignorance, but here goes.
      I hope that this is in the right forum if not sorry.
      What is the spindle bore of a Myford ML7, small bore and big bore.
      I'm trying to identify which one it is.
      Is there a difference is the outer dia, I.E. are the chucks interchangeable without having to change the backplate. I recently aquired this current machine, I have had a Myford before, a super 7 b pxf, but the chucks came with it, so totally in the dark.
      Thans in advance everyone.
      phillip burbank
        Spindle bore
        #571025
        Brian Wood
          @brianwood45127
          Hello Phillip,
          Welcome to the forum.
          I can't answer part 2 of your question on a big bore Myford, the standard S7 has a bore of 16 mm.
          #571031
          DiogenesII
            @diogenesii
            If it's an ML7 I'm fairly certain will be a small bore, using a standard myford 1 1/8" thread, the Big Bore S7 is a 40-something mm metric size spindle nose – the backplates & mountings are totally different and not interchangeable, to the best of my knowledge – maybe someone can confirm..
            #571032
            noel shelley
              @noelshelley55608
              I don't think there was a big bore Ml7 it's bore is 5/8" ! and welcome aboard ! Noel.
              #571033
              ega
                @ega
                Brian Wood:
                I have a feeling that the S7 bore has varied slightly – I don't think mine will accept 16mm (or even 5/8"!).
                #571035
                Nick Clarke 3
                  @nickclarke3
                  Posted by ega on 12/11/2021 17:17:01:
                  Brian Wood:
                  As Brian has suggested I too have heard that it has varied over time – however the early documentation says it is 19/32"
                  #571039
                  Greensands
                    @greensands
                    In general the bore size of a Myford Super 7 spindle will not accept 5/8" bar stock, a fact which I have always found to be very frustrating. However, I do recall having a conversation with Chis Moores some years ago at an exhibition where he told me that subject to individual inspection Myford did offer a special machining service to carry out the reboring operation stressing the fact that it would not be possible to do on every unit. Hope this helps.
                    #571044
                    Thor 🇳🇴
                      @thor
                      The big bore Super 7 Plus has a M42.5 x 2 mm pitch nose and a 4 Morse taper socket and will pass a 1" bar.
                      Thor
                      #571045
                      Brian Wood
                        @brianwood45127
                        I quote from my own experience. It is a tight fit but my ML7R will pass 16 mm
                        #571048
                        Harry Wilkes
                          @harrywilkes58467
                          H
                          #571112
                          ega
                            @ega
                            Posted by Greensands on 12/11/2021 17:42:33:
                            It sounds as though later production Sevens had a slightly larger bore and that smaller bore owners would not be advised simply to enlarge their spindles to 16mm by drilling from the tailstock (also, I believe the taper is hardened).
                            #571114
                            Brian Wood
                              @brianwood45127
                              ega,
                              The spindle bore is not hardened
                              #571116
                              Mike Crossfield
                                @mikecrossfield92481
                                The maximum bore size in the small bore 7 series lathes is limited by the MT2 dimensions. The small end of a standard MT2 taper is .572 inch diameter, which is roughly 14.5 mm. The MT2 taper is .050 per inch, so if the bore is opened up to .625 (5/8 inch), roughly 16 mm, you lose about an inch of the taper. This seems to have been done on some late machines, but on my early ML7(long gone) and Super 7 the minimum bore is less than 15mm, though beyond the end of the morse taper the bore opens up to more like 16mm. Same story on the late model Speed 10 I had at one time.
                                #571145
                                ega
                                  @ega
                                  Posted by Brian Wood on 13/11/2021 11:07:48:
                                  ega,
                                  Thanks for confirming this. What I had in mind, however, was that attempting to open up the bore at the tail end of the hardened taper could be problematic; no doubt a carbide-tipped tool would help but as Mike Crossfield points out some of the taper would be lost – not necessarily a major problem, of course.
                                  The varying size of the bore becomes apparent to those who make J A Radford's stop bars; the major diameter of his Super Seven spindle was 0.621" and the smaller end near the chuck 0.580".
                                  JAR was not averse to modifying his Myford, notable with respect to the narrow guide of the saddle, a modification whose principle was I understand later adopted by the makers.
                                  #571165
                                  Howard Lewis
                                    @howardlewis46836
                                    My memory of my ML7 was that the taper was 2 MT so that anything much larger than 1/2" was unlikely to pass through the spindle.
                                    This was one of my reasons for moving to a larger machine!
                                    Being a coward, I would be wary of enlarging the bore, for fear of the thinner wall weakening the spindle and degrading rigidity and accuracy. No doubt, the Spindle OD and 2 MT taper were considered to the best compromise of strength and facility within the cost target for the machine, in its intended market..
                                    Getting it wrong might be a very expensive error!
