Myford Ml7 micrometer dial.
Home Forums Manual machine tools Myford Ml7 micrometer dial.
  • #478890
    Bootlegger Blacky
      @bootleggerblacky
      Hello,I was wondering if anyone out there has a drawing to make a crosslide micrometer dial for the ML7. It seems they are not available anymore and were quite pricy too. It would make a worthwhile project. Thanks
      Bootlegger Blacky
        @bootleggerblacky
        Drawing request
        #478924
        Nick Hughes
          @nickhughes97026
          There are resettable dials available in either Imperial or Metric from Myford Ltd :- ML7 Resettable Dials
          I use these on my vertical slides.
          Nick.
          #478928
          Malc
            @malc
            There is a detailed article on making these in the Geo.H.Thomas book “The model engineers workshop manual” (P. 164). I made a pair for my ML7 several years ago and have found them a worthwhile feature.
            #478942
            ega
              @ega
              Posted by Malc on 10/06/2020 15:44:18:
              No doubt you first made one of his dividing devices and the tool for engraving the graduations!
              #478947
              Malc
                @malc
                Yes, I had forgotten I had made a dividing device using the lathe screw cutting gears. I cut the graduation marks just using a V shaped tool on its side in the tool post and moving the cross slide along the bed up to a pre-set stop, several shallow cuts each time. I think there is a picture of one of the finished dials in my photos. I seem to remember I also made a jig to guide the number stamp for punching the numbers. I have seen far more professional looking jobs on these pages but for a non engineer the dials turned out well enough and have certainly been useful and accurate enough for me.
                #478959
                Enough!
                  @enough
                  You could also look at dials that are available as spares fore current small machines – imported mills and lathes.
                  I fitted these from LMS to my ML7 but you could probably find something similar locally.
                  #479021
                  ega
                    @ega
                    Posted by Bandersnatch on 10/06/2020 18:37:50:
                    Apart from potential import costs, they make the Myford item look rather expensive even though they don't seem to be re-settable in themselves.
                    #479035
                    Enough!
                      @enough
                      Posted by ega on 10/06/2020 22:39:13:
                      I bought the dials and the friction springs that match. I made simple adapters to fit them to the ML7 and they can turn continuously against the spring-friction. So re-settable. I believe that's how they are used in their original machines.
                      These are standard spares for common machines, which machines are probably available in the UK and elsewhere. So it's possible the dials are available too. I didn't mean to imply he should get them from LMS (necessarily). It was just an easy place to point the link at showing the ones I used.
                      #479091
                      OldMetaller
                        @oldmetaller
                        By sheer coincidence I've just been reading ME 3536, 7th May 1976. On p450 there is a short article on making these dials, with what looks like a good, clear drawing.
                        I'm not sure if I'm allowed to post a scan of this article here, maybe a Mod could tell me?
                        John.
                        #479162
                        Bootlegger Blacky
                          @bootleggerblacky
                          Ok,that’s great,I’ll just buy the mag! And have a good read,thanks.
