Wow, What an overwhelming response. Thank you all for your suggestions.
Ian; poly V belt sounds like a good idea, as Micheal suggested I could add poly V grooves in the existing pulleys, i think i will try this, so thank you both.
Norman; that is a little beast of a machine, some great ideas there.
Ady1; i was looking at thise link belts, they seem like a good idea, especially with the ML4 pulley system.
Phil; it would be great to read those issues, Thank you and i will message you shortly.
John; again, great advice, I don't suppose you have and picture of what you did to your ML4? It would be great to see them.
Thank you all, I hope i havent missed anyone out.
I have waited for months to get a lathe and when I got it I couldn't resist taking it apart. 😀 in all fairness it was in a state and the sliders slip, while looking at rectifying it I noticed there isn't much material above the threaded hole so I am going to mill the threaded nut part away and machine a brass plate to replace it. I will add some pictures to help explain as soon as I can. But thoughts on this anyone?
thanks again, what a great bunch of blokes.
Berty
