AFAIK the only difference between imperial and metric S7 is the crossslide and topslide screw pitches. which as Bernard says are both 2mm pitch. The Xfeed dial is marked in mm off diameter however, i.e. t turn is 4mm. The leadscrew is 8 tpi in both but (un)helpfully the handwheel is calibrated in metric! i.e. 3.175mm full turn.
Edited By John Haine on 12/04/2023 15:57:22
