Hi Adam
Just to be clear, this thread about swapping the tumbler gear refers to use with the Myford gearbox. You will not need to change the quadrant that supports the gears driving the gearbox. From the attached picture you can see the locknut at the bottom that secures it. With a 24T standard tumbler gear fitted and there is about 3/8" movement left in the slot. It seems that most people can fit the 34T tumbler and there is just enough slack in that slot to adjust for that largest gear. If there is not, then you can simply hand file a little more length to the slot.
I have had quite a few enquiries for my spreadsheet so this tumbler gear swap, to quickly obtain Metric and BA threads from the Imperial gearbox, is still popular.
Best wishes
Norm
