The stops on mine were numbered, as were the tool positions on the turret, the numbers should correspond. If they do not, lift the turret a bit and rotate stops until numbers are in correct positions. It can be a bit tricky to get the timing right. It's also a bit tricky to fit the attachment to the lathe bed, you have to remove the keep plates and there isn't much room to get them on again, don't turn the attachment upside down with the keep plates off, the screws disappear inside and it's a royal pain to retrieve them if they jam the slide. It's a nice bit of kit when you get it set up though.
